Old 11-14-2014, 05:07 AM   #99
Gainesville , Florida
Tell me about it! Jim
Old 11-14-2014, 05:27 AM   #100
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Hard water for bathing is particularly annoying when we're used to soft water. The soap won't lather and it takes longer to bathe and really feel clean.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-27-2015, 06:55 PM   #101
TommieDee54
TommieDee's Avatar
2013 30' Flying Cloud
Clayton , Georgia
Do you drink the water at RV parks?
Y'all could buy a Berky Water Filter. Ours is 1 1/2 gallons, filters out everything except pure water. It's classified as a water purifier.
It's the only water we drink, no hauling bottled water or worries about water from the fresh water tank, no matter where we fill it from.
http://www.berkeyfilters.com/
TommieDee54
TommieDee
TommieDee is offline   Reply With Quote
Old 01-27-2015, 07:09 PM   #102
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
Crud, I drink the water from sewage reclamation plants... Sorry, I'm a little bit into happy hour right now.
-Red, if it don't stink, I drink...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 01-28-2015, 07:22 AM   #103
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by TommieDee View Post
Y'all could buy a Berkey Water Filter.
Not until I know what their filter medium is made from. All I could find out when researching the subject was that it uses a micro-pore design that keeps the water in contact with the filter media for a long timeó flow rate is only 7 gallons per hour with the Big Berkey modeló but that's only it's structure, not its composition.
There is no one treatment method that will remove all contaminants identified in the EPA Primary Drinking Water Standards, advertising hype notwithstanding. The Berkey filters appear to concentrate on pathogens which are best removed by granular activated carbon, and heavy metals, best removed by manganese greensand. If I knew what the filter media composition was, I'd know what contaminants it won't filter out.
A Berkey is great stuff if you need emergency drinking water from an untrusted source, and I might buy the smallest model to add to my hurricane "hunker-down" kit for those storms that aren't bad enough to require evacuation but that are likely to disrupt utility services.
But as a general filter for the type of camping I do, I want something with a higher flow rate that I can hook up in-line to filter the municipal or well water before it gets into my Airstream, not something to filter one glass or pitcher of water at a time.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-28-2015, 09:51 AM   #104
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Just bourbon.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 01-28-2015, 12:31 PM   #105
Portland , Oregon
In-line culligan filter between the spigot and the trailer inlet.
Seagull under sink filter for all drinking/cooking water needs.
According to the manufacturer:
"Our proven and patented "Structured Matrix" water purifier systems developed nearly four decades ago, can remove a broad range of contaminants including, water borne disease carrying micro-organisms, toxic or carcinogenic chemicals, sediments, bad tastes, odours, isotopes and other particulate matter including chlorine!"
2015 Nash 24M
2014 Tundra DC Limited TRD (Sold)
2016 Ram 3500 CTD SRW CC
Blue Ox SwayPro
Still looking at Airstreams....
MacPDX is offline   Reply With Quote
Old 01-28-2015, 03:05 PM   #106
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
If the CG is full of live campers having a great time I figg'r the waters good.
I do bring filtered water from home for the Joe. (Distilled in a pinch)
FWIW...never been 'hooked-up' to a water supply. We use a water stealer & inline filter at the CG's we go to.
Old 01-28-2015, 04:48 PM   #107
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Unless we're winterized, we hook up and use the campground water. This year we'll use a high-flow regulator and a filter outside the trailer to ensure no sediment gets into the lines or the fresh tank. To be clear, we're not aware that we've had a problem with water line sediment before, so it's more of a belt / suspenders thing.
The AS filter under the sink in the kitchen is nice, but it only filters water coming out at the kitchen sink. The built-in pressure regulator is nice too, but it doesn't protect the hose or external filter. So, this year we're doing that stuff externally.
Maybe we should add a venturi attachment that pulls bourbon from an IV bag as it goes through the filter - you know, to sterilize things on the way to the trailer.
Old 01-29-2015, 12:27 PM   #108
1977 23' Safari
1986 34' Limited
Idaho Falls , Idaho
We don't use any filter at all. We have well-water at home, and we fill several gallon jugs at the outset of any trip but use them only if we are boondocking or the taste of the CG water isn't good. We prefer to travel with the trailer as light as possible, so only fill the fresh water tank a quarter full for toilet use.
We do Clorox the fresh water tank in the spring, but don't really trust the "green things" not to come back, thus the water jugs filled from home. So far, no problems!
Vivian
Richard and Vivian
Caliban The Wonder Dog: gone but not forgotten
Cerberus
Too many vintage A/Ss...
Landshark is offline   Reply With Quote
Old 01-29-2015, 04:47 PM   #109
1999 30' Excella 1000
small town , Maryland
Originally Posted by zigzagguzzi View Post
Ditto on the dog water. Our dogs are very sensitive to some water, yet get along well with any bottled water! Some campground water bothers them. Go figure, so we buy water for the dogs and us. Jim
I think the dogs are trying to tell us something. If they don't drink the water, we shouldn't either. They have a keen sense of smell . In fact they have 220 million olfactory receptors in their nose, while us humans have only 5 million. I had to Google this information. I use ''zero water'' filter decanter at home. It comes with it's own tester. On the trail a ''Sawyer'' filter, best price is on amazon 20.00 or you can pay 29.99 at Bass Pro. I think everyone should have a ''Sawyer'' just in case....I may not be the sharpest tool in the shed but I'm handy.
streaminwild is offline   Reply With Quote
Old 02-03-2015, 06:07 PM   #110
1972 27' Overlander
Denver , North Carolina
Anyone remember when we actually drank water from the faucet !!! Shudder....
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 02-04-2015, 02:02 PM   #111
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Drinking tap water is oh so low brow...
Old 02-04-2015, 02:04 PM   #112
Maybe. But when was the last time you heard of someone being arrested for drinking tap water and driving?
WBCCI #1105
TAC LA-4
Do you drink your fresh water tank water? pageclot Fresh Water Systems 81 09-03-2009 09:56 PM
March 2008 Photo Contest...Drink Up ! klattu Photography 118 04-01-2008 09:44 PM
29 Palms, Poll for Food & Drink codybear Forum Rallies & Meet Ups 14 12-06-2006 04:02 PM
Favorite trailer time (or anytime) drink recipe: Buttercup Stella's Kitchen 38 10-23-2005 12:06 AM
Don't drink the water!!! crazylev On The Road... 4 08-30-2004 10:21 AM
