Old 11-11-2014, 11:50 PM   #43
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Even an elbow will impact water flow.
The multiple regulators and filters are going to have some kind of impact on flow.
How much? IDK.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
J. Morgan is online now   Reply With Quote
Old 11-11-2014, 11:56 PM   #44
2007 22' International CCD
It's a bit of a fable, but a good brass adjustable regulator is not a bad idea. Just don't try to use one of those so-called RV regulators that looks like a short bit of brass with hose fittings on each end. The flow rate is very slow and it does not really regulate pressure like a big expensive one. I took that POS off when I discovered it makes our tankless hot water heater act strange.
I do put an external filter at the AS city water port to help clean up the water taste. Never had a potable water hose blow out or a filter blow out its innards due to pressure. I carry a water pressure gauge as a sanity check when I hook up to the supply valve.
Old 11-12-2014, 04:57 AM   #45
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Many RV parks require the use of the short brass water pressure regulator and offer them for sale if you don't have one. For some reason they see it as superior to the short blue plastic one.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-12-2014, 08:46 AM   #46
Hm, last couple trips we stayed in one KOA that had signs up saying NOT to use those type regulators. I suspect it was low pressure in the park water system.
I plan to get an adjustable one that has a better flow rate. The typical cheap one can't flow enough water for taking showers in places like that. Interesting that some require them--trying to save water, I bet!
Old 11-12-2014, 09:17 AM   #47
SteveH's Avatar
Common Sense , Texas
We've actually been in park that required water pressure regulators in Moab, UT because of high pressure. The people parked next to us in a fifth wheel did not use one, and when we came back from the day's excursion with the hot sun beating down on the hose, it had burst and of course water was running everywhere. So, there is a reason for using them.
Regards,
Steve
Old 11-12-2014, 09:30 AM   #48
Skater's Avatar
1995 30' Excella
Bowie , Maryland
We usually drink the campground water, albeit filtered with a second tap at the kitchen sink. We do carry a few bottles of water for day excursions, but in general the filtered water does fine for us.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 11-12-2014, 09:35 AM   #49
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Most of those fittings that are "required" on campground hose bibs are backflow preventers, not pressure regulators. They do look very similar. There is a way, just by looking, that you can tell the difference. Look at the perimeter of the female end, where it is attached to the hose bib. If there is a set screw in the side that prevents it from being removed, its a backflow preventer. The set screws' head is designed to break of at a certain torque when it is tightened, so that the backflow preventer cannot be removed by hand. A pressure regulator can be removed, no set screw.
The reason backflow devices are needed in campgrounds: If someone would turn on their pump to their fresh water tank and there is no backflow preventer, it could insert water out of their FW tank into the public water system.
Alan
Old 11-12-2014, 09:38 AM   #50
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
What's wrong with the built-in Airstream water pressure regulator?
Doug and Cheryl
Old 11-12-2014, 09:48 AM   #51
Nothing. But it does not protect the hose. As said above, A flexible hose in the hot sun, add high water pressure, and it could burst An external regulator with a decent flow rate prevents that, also protects an external filter like I use.
Only issue IMHO with an expensive external regulator is that it may attract thievery. It's a fairly small risk the way I camp.
Old 11-12-2014, 10:08 AM   #52
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
The external water pressure regulators that we have always used are not very expensive (around $12) and easy to use. In over 1,500 nights of Airstream camping, we have never had one stolen.
I like the extra pressue protection of the external regulator. It's not that I don't trust the internal Airstream regulator, it's just that the failure of an internal water line could be devastating. I have such a fear of this happening that I always turn off the pump or the city water supply at the trailer.
Brian
SuEllyn & Brian McCabe
Old 11-12-2014, 10:15 AM   #53
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
We drink the campground water. Campground hose bib + brass pressure regulator + in-line blue water filter + white hose + brass 90 degree elbow + Airstream. No issues.
Cannonball is offline   Reply With Quote
Old 11-12-2014, 10:48 AM   #54
2017 25' Flying Cloud
2014 23' FB Flying Cloud
2008 20' Safari
Chino Valley , Arizona
Most campgrounds with full hookup usually have the fresh water valve right next to the sewer dump and most campers use it to flush out their black tanks. I carry a spray bottle with bleach and spray down the fresh water valve before attaching the hose to my AS. I also install a sediment filter.
AIRTRVL is offline   Reply With Quote
Old 11-12-2014, 11:04 AM   #55
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If I saw a connection similar to the one pictured by Moosetags, I wouldn't use that water in my Airstream. Most states that I'm aware of (which doesn't include all of them) require a horizontal spearation of 10 feet between water lines and sewer lines, OR, if they can't be separated that far, the invert (bottom elevation) of the water lines has to be at least 18 inches above the top elevation of the sewer line. Where you've got a sewer connection as close to a water line as in the picture, there is no vertical separation because they both come up to ground level, and the horizontal separation is measured in inches, not feet. Mere proximity to the sewer connection is enough to have that water source declared non-potable!
(The reason is that if both lines happen to leak, you can get cross-contamination.)
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-12-2014, 11:07 AM   #56
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
I've never seen one quite that close! Eeeewww!
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Do you drink your fresh water tank water? pageclot Fresh Water Systems 81 09-03-2009 10:56 PM
March 2008 Photo Contest...Drink Up ! klattu Photography 118 04-01-2008 10:44 PM
29 Palms, Poll for Food & Drink codybear Forum Rallies & Meet Ups 14 12-06-2006 05:02 PM
Favorite trailer time (or anytime) drink recipe: Buttercup Stella's Kitchen 38 10-23-2005 01:06 AM
Don't drink the water!!! crazylev On The Road... 4 08-30-2004 11:21 AM
