Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 08-06-2004, 11:36 PM   #1
5 rivets, 1 loose screw
Rog0525's Avatar
Profile:  1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Smile Daffynitions, AS ads
This is all in fun folks, no offense to honest sellers. Here are some frequently used terms often seen in Airstream ads and the revised term I would use after actually seeing the units. I once looked at an older coach where the axles were totally shot. The seller told me that Airstream designed this particular model for easy step-in.
Care to add a daffynition on any you've looked at?
Custom Interior: Sofa has been replaced with lawn chairs.
Fixer Upper: The salvage yard didn't want it.
Good tires: The tread is deeper than the weather cracks.
Have Not Tested The ______: It doesn't work.
Low Profile: Axles are shot.
Mint Condition: Towable
Modified: Duct-taped.
Needs Some TLC: See Fixer Upper.
New Flooring: I tossed in a throw rug.
No major dents: Lots of minor ones.
No Title: Cousin Clem asked me to look after it 'til his parole hearing.
Original Equipment: I didn't install it.
Partially gutted: The stove is still there but I haven't tested it.
Polished: Waxed.
Priced For Quick Sale: No takers on my last 3 ads.
Rare: It's the only one in my driveway.
Slight Hail Damage: Dimpled like a golf ball.
Some Water Damage: This unit is located 2 miles downstream from my house.
Unique: No other unit has the same serial number.
Upgraded: I slapped some paint on it.
Wheel Bearings Repacked: I removed the hub caps and stuffed in some grease.
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Old 08-07-2004, 06:56 AM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
You asked for it...
Recently refurbished- washed last week
Custom lighting- found a lava lamp in a drawer
Original condition- nothing works, so we left it in the trailer
Has had axle work- has a new set of Kmart hubcaps
Plumbing upgrades- a piece of garden hose now goes to the toilet
A/C works- if you are in Alaska in February
Towing equipment included- couldn't sell it separately
Tows well- could be dragged across the street (maybe)
No leaks- it is in a desert
(No Longer at Inland RV)
Old 08-07-2004, 07:08 AM   #3
sd90mac's Avatar
lost , somewhere
Rare Gem-Found in the swamp
Custom Paint-Painted over with spray paint (canned)
Vintage-Some one will buy it if I say it's rare
Genuine Airstream- it's silver
Marie
When people lie to you, and refuse to honor their word, don't regret trying to follow a dream, new adventures and friends await you.
sd90mac is offline   Reply With Quote
Old 08-07-2004, 09:26 AM   #4
JohnG's Avatar
Profile:
Never been smoked it – Never been on Fire.
New Door Locks – Hasp and padlock.
Normal Wear & Tear for its age - Worn out, dented, dinged, clear coat peeling, leaks here and there, and floor rotted in small places.
Reupholstered – Patch sewed over burn hole.
Smoked in – Had a small fire that didn’t destroy it.
Tinted Glass – Glass has spray paint on it.
Upgraded Upholstery - Ugly style nobody wants.
Just adding my 2˘ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 08-07-2004, 10:32 AM   #5
moderator
Janet's Avatar
Profile:  Eastern , Washington
Images: 65
Airstream Registry
Must see to appreciate: The 1200 mile trip to look at this heap will wear you down, lower your standards and make you so bleary eyed you won't care about the rotted floor, cardboard covered windows and ruptured water lines.
Could be Wally's own trailer: I also have a bridge for sale.
77 Argosy Minuet, 6 metre | 77 Argosy 24, Rear door
AIR # 3181 | WBCCI # 5575
Bullies thrive where leadership fails
Janet is offline   Reply With Quote
Old 08-07-2004, 12:48 PM   #6
Master Riveter
Sneakinup's Avatar
Profile:  1972 27' Overlander
. , Mobile-- as in transient
Images: 72
Send a message via AIM to Sneakinup
You can find others from a thread I started some time ago called... Airstream Terminology
1972 27' Overlander 72 Overlander
Jack Pad--- A notebook used by Jack Nicholson in the Shining to keep track of how much work he had done on his Airstream. "All work and no polishing makes Jack's Airstream a dull trailer"
Sneakinup is offline   Reply With Quote
Ads on the forums... Andy R Our Community 9 07-18-2004 03:57 PM
Sickly Ads For Airstreams make me Puke LOL RichardT Our Community 17 03-13-2004 12:11 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
