Old 12-02-2005, 02:00 AM   #1
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Custom key chain holder
I was tooling around today and decided to make this.It is my first one so one side got kinda messed up but I have plans on making a second one that will be perfect hopefully with no flaws.Here are some pics.I just though some of you might be bored and want something to do possibly.
ID:	16788   Click image for larger version
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 12-02-2005, 02:01 AM   #2
Devoman's Avatar
more
A couple more.
ID:	16791   Click image for larger version
Old 12-02-2005, 02:02 AM   #3
Devoman's Avatar
one more
Last one.
ID:	16793   Click image for larger version
Old 12-02-2005, 02:20 AM   #4
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
Key Holder
Hi Devoman :
Looks good
About how long did it take yo to make it?
Take care,
Safari=Rick
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 12-02-2005, 06:26 AM   #5
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Now this is the perfect example of the difference between the gifted and the not gifted. I just screwed a hook in and put the keys on it. I think I need help. I did hang the vinyl wall covering myself. That should count for something.
juel is offline   Reply With Quote
Old 12-02-2005, 06:30 AM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Juel,
Form follows function...I much prefer function BTW love the tassled door hold back...mine is a piece of yellow poly rope at the moment...the interior decorator hasn't been in yet
Aaron
WBCCI #XXXX AIR #2495
Old 12-02-2005, 07:47 AM   #7
Devoman's Avatar
time
I am gonna say it took me around 30 to 45 minutes to do this.The drilling is the part you have to be slow and patient with.I took two screws and mounted it on a piece of 2x4 so it would not move around.You can flip it over to drill it out. also I took a bigger drill bit to widen the hole in the back so the screw would fit flush.remember to drill really slow when you go through the aluminum it will bend if you force the bit through to fast.The key original key chin holder was bpurchased at home depot.it had the hooks and a piece of wood it was mounted to.I just took them off and went the extra mile to try and match the aluminum is all.The old napkin holder can be purchased at walmart,bed bath beyond or pretty much any place it seems that carry napkin holders.
wanted key blank for 69 Overlander bgow 1965 - 1969 Overlander 4 10-05-2015 12:15 AM
Vote on lost key return service 66TradeWind Community Polls 12 05-01-2009 11:28 AM
Water inlet key replacement Road Ruler Fresh Water Systems 7 09-03-2002 10:07 PM
Custom Designing Cat Cabinets, Counter Tops & Furnishings 0 07-22-2002 03:09 AM
door key tomb Doors & Locks 8 07-17-2002 12:16 PM
