Old 11-13-2005, 07:18 PM   #1
danesh's Avatar
Question Cover for Winter
Hello All AS Owners:
We just winterized our 85 Sovereign and want to have it stored under some sort of cover during the winter. Last few years we had it sit under the blue skys, which was not such a good idea . We park our AS on the north side of our garage on a 30x12 feet concrete pad. On one side is the garage wall and the other side is dirt (planter). The width of the parking area is 12 feet. We use a Power Mover Dolly to park our AS in such a tight spot. We have a few questions and appreciate some advise :
1.We could buy a RV cover and cover our AS directly with it. There are many different types out there. Is this a good idea and if yes, any suggestions for the brand to buy? The only concern we have is that we have heard that one should not use RV covers directly on the AS because it may cause skin problems.
2.Build temporary 12x 28 feet RV garage using tubings and tarp. Any plans or suggestions that we could use?
85 sovereign
danesh is offline   Reply With Quote
Old 11-13-2005, 07:33 PM   #2
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
They do not recommend you cover your trailer with a tarp or RV cover because air currents cause the cover to abrade the plasticoat. I have been looking at various types of tarps over a pipe frame which are tall enough for our trailers.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 11-26-2005, 09:45 PM   #3
2001 31' Limited
Tucson , Arizona
Maj
What do you recommend for storing outdoors in the hot AZ summer. Do I need a cover?
M Johnson is offline   Reply With Quote
Old 11-27-2005, 11:56 AM   #4
davidz71's Avatar
1986 25' Sovereign
If you still have the plasticoat on your trailer then you would probably be best off building some type of pole barn. I'm not sure what the cost would be but the idea would be to keep the overhead UV exposure to a minimun. The top of my '86 is balding but the sides are fine. I can't see having it polished and recoated to have the thing redone every 5 years when the coating starts to peel again.
Craig
AIR #0078
3.73 rear end
Old 11-27-2005, 12:14 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Shade! Anyway you can get it. I had my Tradewind in full Phoenix sun for a few weeks and the inside temps would go to around 150 degrees.
Richard
Old 11-28-2005, 02:56 PM   #6
1973 31' Sovereign
Portland , Oregon
Images: 22
Make your own canopy...
There is another thread talking about temporary RV shelters as follows:
http://www.airforums.com/forum...ers-19380.html
In it I posted a pointer to a company that makes brackets that can be used to construct your own tubing framework for covering with a tarp. Perhaps you could rig up something that would meet your needs with some combination of the products they supply.
http://www.tentcoinc.com/
Malcolm
malconium is offline   Reply With Quote
64 Globetrotter Stove Vent Cover Trotter Roof Vents, Skylights & Fans 2 12-15-2007 07:03 PM
vent cover repair.... Chuck Windows & Screens 10 11-13-2002 01:05 PM
cover for univolt maznblu Electrical - Systems, Generators, Batteries & Solar 2 09-15-2002 08:02 PM
Need Suburban Furnace Cover For 79/31' Soverign montanaandy Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-29-2002 11:54 AM
Trailer Life cover 83Excella Our Community 6 06-16-2002 11:14 AM
