Originally Posted by Nicksut
Hi, I once found a site with original manufacturer specs for all Airstream Trailers built since.... way back 50s?? Now I can't seem to Google it. Anyone know where this info is? Thanks, Nick
Nick,
If you found this site using Google, then you should be able to find it again simply by hitting the down arrow on the right side of Google's blank window.
Also, you might check and see if the cookies for that site are listed on your puter. (Unless you use a cookie delete program)
Further more, if you're using Window XP and, bring up your IE..On the far right hand side is "link" stored for websites visited. (Next to where "go" is)
Just maybe some of this will aid you in your search~!
I have other methods available but...it require you to have these program features built into ur puter..
ciao
53FC
