05-17-2005, 11:02 PM
Administrator
1961 16' Bambi
Dallas
Community karma system - Discussions
This thread is for discussing the community karma system from this thread:
Community karma system info - Overview & FAQs
A member's "influence or reputation power" is based on the following formula:
- 1 point for each year of membership
- 1 point for each 250 posts
- 1 point for every 50 karma points you earn
The amount of karma you earn (or loose) is based on the "influence or reputation power" of the person giving you feedback. So if a member has an "influence or reputation power" of 8 and they give you good karma then your karma increases by 8 points.
Here are other rules- You can only give 10 people karma per day
- You have to give 10 different people karma before you can give the same member karma again
- All members have 10 karma points by default
- If a member has less then 5 karma points their "karma hits" do not count towards any other members until they get their karma back above 5.
- A member must post at least once before their "karma hits" count toward other. So if a member has never posted, they can still leave karma but it wont have any effect on the user.
- Questions and answers from this discussion will be added to the closed post above so we can continually evolve that post to answer as many questions in one place....
05-18-2005, 08:06 AM
1961 22' Safari
Vienna
Ok, this is a bit confusing to me!
First, where can we see the calculation of different member's "influence or reputation power?" Do we just see our own (where?) or can we see everyone's rating for this?
Does this mean that if you don't earn karma that you can't give away anymore after you use up your initial 10 points? Or do you automatically have 10 points to give away each day?
Also, since we all start below 5 points (thus nobody has counting karma points), it doesn't appear that there is any way that anyone can accumulate enough karma points to give karma points. This leaves me puzzled.
Thanks to anyone who can set me straight!
Mary
05-18-2005, 08:51 AM
1958 30' Sovereign of the Road
Plymouth
, New York
Addition
1+1-1+1+5-5-1=0
05-18-2005, 08:57 AM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Originally Posted by robandzoe
1+1-1+1+5-5-1=0
Uh...I don't think so, try again!
Shari
05-18-2005, 09:01 AM
Plymouth
, New York
"One"
It actually equals one, but I too had a hard time figuring out the Karma formula. Yes, I will be playing around with the Karma tool. Can you tell if people are giving you good or bad Karma - a Karma history if you will?
Rob
05-18-2005, 09:04 AM
1956 22' Safari
Conifer/Evergreen
Rob
You should be able to check it in the UserCP ~ if not now, soon.
Shari
05-18-2005, 09:13 AM
2010 27' FB Classic
Cape Cod
, USA
Seems simple enough
Whatever you are be a good one....'Abraham Lincoln'
WBCCI #9204, Region 1, 1st VP NEU
TAC #MA-4
1968 26' Overlander
Wenatchee WA
, Cape Cod
You can see what you have recieved Karma for, but not who gave you the Karma, in your user CP
Jim & Kathleen 1968 Overlander - WBCCI #5793
05-18-2005, 09:46 AM
1961 22' Safari
Vienna
Actually if I read the first post correctly, since nobody has any karma points to start with, then nobody has the sufficient 5 points earned to be able to give away karma points that matter. So, no matter how many you give away, the system can't get started.
Right?
Mary
Originally Posted by M&M CAPECOD
05-18-2005, 09:48 AM
1956 22' Safari
Conifer/Evergreen
Ooops, sorry!
Guess that's one of the settings that is different for the mods. It's probably a good thing so members don't give or take karma on just a retaliatory basis.
Shari
05-18-2005, 09:50 AM
1956 22' Safari
Conifer/Evergreen
Right?
Mary
No, everybody starts with 10 points...
Shari
05-18-2005, 10:17 AM
1964 19' Globetrotter
OlyPen
You can leave a comment with your karma addition or subtraction and I suppose until you can see who left it - you could include your user name in the comment.
05-18-2005, 10:23 AM
1961 22' Safari
Vienna
Shari
That's much better, I think I starting to get it. Is this how it works?
- I give away 1 point to "Fred." My balance is 9. I cannot give any more to Fred until I've given away 9 more karma points to other people (total 10).
- I give away 4 more points. My balance is 5. I can give away the other 5 points, but it won't matter until I earn more points myself.
- I give 1 point to "Agatha." My balance is 4, but this won't count until I earn more points myself.
- I earn a point. My balance is 5. Agatha's point counts.
- I give away 5 more points. My balance is 0. I cannot give away any more points.
- I earn 1 more point. I have a balance of 1. I can give it to Fred, but it won't count for points until I earn 5 more points myself.
So, do I get it?
Mary
05-18-2005, 10:28 AM
1956 22' Safari
Conifer/Evergreen
No, you don't lose points by giving them away...but you can only give 10 away, per day to different people. You can't give (or take away) karma to the same person over and over...only once per 10 points given. Only others can take karma away from you...kinda like feedback on ebay, you don't lose points by giving them. Your 'power' determines the value of your karma...if you have been around awhile, posted alot or accumulated a bunch of power your karma counts more. If you are a newbie or have negative karma based on your own posts and karma received, your karma doesn't count as much. Make sense?
Shari
05-18-2005, 10:44 AM
2020 30' Flying Cloud
1995 25' Excella
Clear Lake
Is Karma also earned by giving? Seems that giving might also create Karma in the "real world" although that would generally be because someone knew you were giving them positive "Karma".
Mark
72 Sovereign: L couch, mid-twin, rear-bath "When you come to a fork in the road, take it" "It was impossible to get a conversation going; everybody was talking too much." "If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
05-18-2005, 10:50 AM
1956 22' Safari
Conifer/Evergreen
No, you don't get it by giving it...it's that 'Random act of kindness" thing. What goes around, comes around ~
Shari
05-18-2005, 11:03 AM
1995 25' Excella
Clear Lake
A little positive real world Karma to Shari!
(already gave the private electronic way) Just coming back around a little...
Mark
05-18-2005, 11:13 AM
1968 17' Caravel
2005 30' Safari
Somewhere
, roaming America
If you heat your sweetest posts in a pan, will they "karmelize"?
05-18-2005, 11:26 AM
2010 27' FB Classic
Cape Cod
, USA
TAC #MA-4
05-18-2005, 11:46 AM
1961 22' Safari
Vienna
I think I am more confused than ever, but I'm just going to give Karma as I can, I suppose!
Rich, that's a true groaner!
Mary
