Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 08-28-2003, 04:53 PM   #1
KIMILI's Avatar
2004 25' International CCD
Salem , Massachusetts
Wink Check Lists
Hi fellow AS lovers,
as many here we're newbies and don't have much experience with certain AS fundamentals.
We understand and share the importance of a GOOD CHECK LIST, both pre-trip and post.
Anyone here care to share their check lists?
thanks, cheers
KIMILI
KIMILI is offline   Reply With Quote
Old 08-28-2003, 05:12 PM   #2
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Here's mine so far - we think of something else to add after every trip (and we've only had six or so trips).
Windows Closed
Fridge off
Heater off
Water heater off - Secure door on water heater
Dump black water - add two gallons clean back into tank
cap dump tank
Rinse stinky-slinky and replace in storage
fill water tank and cap it
return water hose to trailer
Unplug trailer
Cap electrical outlet under trailer
Vent Closed
Loose items secured?
Water Pump OFF
Step UP
Front window guard latched
Propane OFF
Propane tanks secure
Examine hitch-head for wear, cracks in bolts or ball, bolts and ball tight
Securely pin hitch in truck receiver
put plastic sheet on ball (or grease ball, whatever you do)
latch trailer onto ball, lock
Crank jack all the way up - Put jack foot in trailer
Remove stabilizer jacks
remove wheel chocks
hook up safety chains
hook up break-away switch wire
install wd bars
put chain tool in trailer
install sway control
(1 full turn past where you can't move it by hand)
Plug in trailer wiring to truck
test right, left, brake, and running lights
Can't wait to see other people's lists...
Stephanie
Old 08-28-2003, 05:30 PM   #3
Vroom
Richard Vroom's Avatar
Mahone Bay
Images: 14
Check List
Airstream Departure Check List
Interior:
1. Turn off water pump switch.
2. Turn off gas to range and oven.
3. Turn off all interior lights.
4. Empty holding tanks and add gallon of fresh water into toilet.
5. TV antenna – lower with crank.
6. Close and lock all windows.
7. Roof vents – shut and lock, including bathroom.
8. Refrigerator – turn on gas and lock door.
9. Lock all cabinet doors and check pantry door.
10. Fasten all sliding doors.
Exterior:
1. Rinse waste water hose and replace in back bumper.
2. Place water hose in box and put in side storage.
3. Electric cord – replace in back bumper.
4. Remove and stow leveling jacks and wheel chocks.
5. Do walk around vehicle to check all outside before departure.
6. Lock outside door.
7. Steps up and locked in place.
8. Last check of hitch before departure.
9. Check safety chains and break-away switch cable.
10. Test lights and brakes.
11. Check tire pressure.
Bon Voyage
Richard Vroom is offline   Reply With Quote
Hitting the road check list smallfry On The Road... 8 12-12-2016 12:52 PM
1986 AS 345 MH H2O Check Valve Location Jim Tyrney Airstream Motorhome Forums 10 10-21-2003 07:47 PM
Univolt reminder ** Battery Check! Sav'h Steve Batteries, Univolts, Converters & Inverters 21 10-07-2003 02:18 PM
Check your aging A/C shroud Jim Clark Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-25-2002 10:30 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
