01-22-2017, 09:53 AM
2015 25' FB Flying Cloud
Meadow Vista
Centramatics?
I have not seen anything recently on the Centramatic Tire Balancers.
Are these still in favor with members of the Forum? What size for a 2017 Classic?
Should i change lug nuts at the same time? If so, what size lug nuts?
SS
01-22-2017, 09:57 AM
Biloxi
, Mississippi
I think they were just another fad. Proper balancing and tire care will do the trick.
MICHAEL
01-22-2017, 10:01 AM
2015 27' Flying Cloud
Newberg
, Oregon
They helped smooth out my trailer, so I'm quite happy with them. I swapped out the AS lug nuts at the same time for McGards. Didn't cost too much and I don't have to worry about the fake cover coming off if I check the torq on the wheels.
Mike
01-22-2017, 10:11 AM
2012 25' Flying Cloud
Battle Lake
With a desire to keep it simple, we have always preferred top quality tires, rotated and balance checked every year or two, depending on miles traveled. Similarly no TPMS on our Airstream.
Doug and Cheryl
01-22-2017, 10:31 AM
2012 23' FB Flying Cloud
Santa Rosa Beach
I've been using the Centramatics for about ten years now. Old Lucy (2005 25FB) clocked 60,000 miles on her Michelin 16" LT's with no appreciable tread wear. New Lucy (2015 25FB) is fast approaching 30,000 miles on her Michelin 16" LT's. I can't guaranty that the Centramatics significantly contributed to this outstanding performance, but I have to think that they did. I have been convinced enough that I recently installed Centramatics on my Silverado 3500 tow vehicle.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
01-22-2017, 10:55 AM
Newberg
, Oregon
This is the difference with Centramatics on my trailer. Before Centramatics, every single trip, the snap in back cushion on my dinette along with the other set in place cushions, would be on the floor, occasionally falling out the door onto the street as I opened it. Post Centramatic installation, this now happens only ocasionally. This is with no other change, on the original GYMs. It will be interesting to see what effect switching to the Nokian tires will have this spring.
Mike
01-22-2017, 12:03 PM
Meadow Vista
Brian
Are your rims 16 inch? Do you recall the size of your Centramatics?
SS
01-22-2017, 01:20 PM
Santa Rosa Beach
SS
I do have 16" wheels and LT tires. I just looked up my Centramatic invoice. The balancers that I have are part number 200-221 Special. Mine were purchased in October of 2014. I would give Centramatic a call (800-523-8473) and speck to the about which part number you need. They are very helpful and knowledgeable about Airstreams.
Brian
01-22-2017, 03:30 PM
Meadow Vista
Brian
Thank you!
01-22-2017, 03:42 PM
2017 23' Flying Cloud
Parker
I put them on a brand new airstream. Not many miles on it yet, but knew I planned to do this. So I tried to benchmark performance by placing things that wouldn't break or do damage (pillow) stuffed animals, empty paper cups.
I noticed less movement of these over the same trips when I put the centramatics on. I think they help as well. Cheap investment, depending on your definition of cheap....
Troutboy
Troutboy
01-22-2017, 04:24 PM
Walnut Creek
When I found a post that explained Airstream balanced the tires, wheels, brake drums and hubs as a set, it was clear why a balancing device like Centramatics was a good addition. If you have a shop that can dynamically balance the tires on the trailer, no need for Centramatics. Given a very well balanced set of drums, hubs, wheels and tires, the Centramatics are not required. Since I have significant doubt of that condition, the Centramatics seemed like a good choice. The $200 cost is not too expensive and they have the added value of balancing out minor changes to the tires.
Lug nuts are a change that makes sense at some point in time. A set of Gorilla splined nuts are a bit less expensive, but you do have to carry the special splined socket.
Travel safe. Pat
01-22-2017, 06:04 PM
Francisco
, Indiana
They are no fad for me. I love them from my Airstream to my semi tractors and antique trucks they work great. Extend tire life for me and make driving more enjoyable.
Hickory
01-22-2017, 06:30 PM
2005 19' Safari
GLENDALE
, AZ
We boondock occasionally, and camp year-round. Consequently, we sometimes have mud, snow/ice, etc., in our wheels and big rocks in our tires. While I cannot prove it, I suspect the Centramatics keep the running gear in balance under these conditions; and our 16" XPS Ribs have worn evenly over the past 6.5 years and 45,000 miles, with no tire rotation.
I would buy them again, and I wish they made Centramatics to fit our Tundra.
01-22-2017, 06:52 PM
Battle Lake
Running balanced Michelins without Centramatics we have never had anything break, come loose, fall, open or get tossed around in our Airstream doing four cross-country trips a year.
Doug and Cheryl
01-22-2017, 07:04 PM
Parker
I read on another thread that you shouldn't put the centramatics on your TV, as it makes it difficult to detect potential issues. Can anyone confirm that or provide info.
I also think Andy from can am recommended against it for TV
Troutboy
Troutboy
01-22-2017, 07:19 PM
2005 30' Classic
Burlington
, Ontario
Not sure why they wouldn't be ok for a TV - 18 wheeler drivers have apparently been using them for years - long before we started using them on travel trailers. maybe thwre is some reason though - Andy T seems to be held in high esteem on the forum.
I did install them quite a few years ago after seeing the very impressive demo on their website.
I have no real quantitative indication of how well they work other than to say that we used to have a lot of problem on the road with drawers coming open, loose screws found on the floor etc., and that is no longer much of a problem.
But then, I have also changed wheels and tires and also fiddled with latches to try to improve them, so who knows!
I guess it takes a bit of a leap of faith!
I did wonder from the outset that since the moving weights were not that great, and their operating radius rather limited, how effective they could actually be?
As a retired mechanical engineer, I suppose I should be able to do some calculations ...... but it has been a long time since I retired, and I never really did much engineering work anyway, so the inclination isn't really there to investigate further!
I have a Honda Goldwing motorcycle, and I know that Centramatic make a set of balancers for the Goldwing.
I don't have them on my bike, but I participate in internet Goldwing forums, and many riders swear they have made significant improvement in the ride of their bikes.
Just anecdotal I know!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
01-22-2017, 08:12 PM
Parker
I think they are okay for the TV alone, but not when towing, as he said it's hard to feel if there is an issue in the combined rig, and you want to be able to feel if something is off....
Troutboy
Troutboy
01-22-2017, 08:40 PM
2015 30' FB FC Bunk
Ayer
, Massachusetts
Dexter Neverlube hubs require 0" offset wheels, do the Centermatics affect this?
01-23-2017, 06:08 AM
Oswego
Yes, slightly, but it isn't a problem. Wheels will standoff .030-.040" maybe. I not heard of any bearing issues from anyone.
-Rich-
01-23-2017, 06:59 AM
2005 30' Classic
Burlington
, Ontario
Troutboy
Well, if that is so, it appears Andy is of the belief that they work!
Brian.
2005 Classic 30'
