Old 07-09-2003, 02:25 PM   #1
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
Caulking underneath?
When I was greasing my BAL stabilizer jacks I noticed the "interesting" caulking job around the driver's side rear jack of the tt.....this was done at the factory I am certain; they caulked around a 1/2" drain and ran the caulking around the jack turning rod. This pulled out the caulking. Great job of caulking--worse than mine
What is the drain from/to? Pretty close to the hot water heater.
Can I use Home Depot's best inside/outstide caulking?
This caulking will not show. There are arrows pointing to jacking points--some square pieces -- are these pieces the actual place where you put the jack head?
Sorry about all the questions.
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 07-09-2003, 04:00 PM   #2
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Jack points
According to my conversations with the factory, the jack head should go at the aluminum square.
John W. Irwin
WBCCI #9632
Old 07-10-2003, 07:25 AM   #3
On my Safari the tube in that area is for draining the city water line between the inlet and the water heater. On my unit there is a valve in the storage area that opens that drain line.
Larry Ruebel
Bismarck ND
Ruebel is offline   Reply With Quote
Caulking above blue molding ? Happycampers Leaks - Weatherstrips, Gaskets, Caulks & Sealants 19 12-11-2004 06:03 PM
310 MH underneath rust Andre Baillargeon Airstream Motorhome Forums 2 09-26-2003 02:00 PM
Caulking Kistler Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-19-2003 12:32 PM
Sealing Windows & Caulking outside mgordon Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 01-13-2003 12:18 PM
caulking ALANSD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 07-10-2002 02:13 AM
