Old 09-15-2019, 02:12 PM   #1
Canít close 2020 Bambi window
Hey all. New Airstream. 2020 22í Bambi. The galley window doesnít fully close shut unless one of us goes outside to slightly lift it as the other stays inside and turns the wheel. Will be at the dealerís for MaxVents installation in a month or so. Until then, is there an easy fix for this. Couldnít find one briefly playing with it. Any info appreciated! See photos.Click image for larger version
ID:	352219Click image for larger version
ID:	352223Click image for larger version
steilkurve is offline   Reply With Quote
Old 09-26-2019, 03:11 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Sorry, not familiar with that window system myself. For the sake of just getting a response on here, I thought leaving my .02 of just not using that window and letting the dealer adjust it. Warranty for airstream is amazing and hassle free. Best of luck!
BigSxyWhtGuy is offline   Reply With Quote
Old 09-26-2019, 03:15 PM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
get a second hand( person) and push it from the outside.
new windows can stick a bit in the frame
waninae39 is offline   Reply With Quote
Old 09-27-2019, 09:27 AM   #4
Yep. Thanks. Wise advice! Got appointment set up. Going in a couple of weeks.
Old 09-27-2019, 11:36 AM   #5
2002 19' Bambi
Lafayette , California
Our 2002 19' has that type of Hehr window and, in the 17 years we have owned it, that very window has not wanted to close. We just tighten up on the wheel and within a few minutes it usually snaps shut. If not, we push on it slightly on the outside. When towing, it will close on its own if the closing/opening wheel is properly tightened down.
Tim
Tim A. is offline   Reply With Quote
Old 09-27-2019, 12:31 PM   #6
2019 22' Sport
Carlsbad , California
5 minutes with a dremel... shave just a touch off the frame on the wall from the outside wherever it is sticking. My 2019 Sport had the same issue with the dinette window.
Prettygood is offline   Reply With Quote
Old 09-28-2019, 07:19 AM   #7
Good solution but a bit too drastic for my taste with a trailer thatís a little over a month old. Iíll keep that as a last recourse!
Old 09-29-2019, 06:54 PM   #8
Shangrila's Avatar
2020 22' Bambi
Bath , North Carolina
Have the same Bambi, 22í. Windows are a little stiff. Bought some of the (3 and 1
RV rubber protectant). After that window closed ok. Just needed a little lubrication.
Lisa and Greyton
Shangrila is offline   Reply With Quote
2019 Ford F150 & 2020 Bambi 22 ft bouncing too much! GeoffyJ Towing, Tow Vehicles & Hitches 73 12-04-2019 11:10 AM
% off MSRP New 2020 Bambi 22 chaeha 2005 and newer - Bambi all models 1 08-15-2019 02:26 PM
Help -spring loaded hinges -can you adjust to soft close?? LAWBC 2009-2015 Flying Cloud 1 07-09-2012 10:12 AM
so close i can taste it... bluegabs Member Introductions 8 08-04-2008 08:57 PM
So close I can taste it! Yak dad Member Introductions 15 12-16-2007 12:30 AM
