Old 08-15-2003, 08:04 PM   #1
Buying a used Airstream
29ft airstream excella supposively in good conditiona and new tires...for $4000...... does that sounds reasonable if it is in good shape......im new to all this but have ran across this one for sale...do you know of any specific problems to address when i inspect it tomorrow. all replies helpfull..
melebe is offline   Reply With Quote
Old 08-15-2003, 08:28 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Rear sag and bad axles. Each of these problems can cost you around $2k to fix, so it can be a big deal.
Do a search here on both sag and axles. If you can fit even a pencil between the frame and the body in back, it's sagged.
Next down the list is the refrigerator. Replacement is about a grand, so make sure it works on both gas and electric. If, on the other hand, it works on one but not the other, it's probably just a broken prart, and maybe on ly half that much to repair.
Air conditioner. $500 or so if busted.
Check the floor for soft spots.
Water leaks. Does it small damp?
Are the propane tanks updated? Are the tires good? Do all the lights and stuff work?
Is the awning fabric ok?
Old 08-15-2003, 08:42 PM   #3
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Re: Buying a used Airstream
You might state how old the trailer is.
Also, is it center or rear bath. Rear bath increases the probability of sag.
John W. Irwin
WBCCI #9632
Old 08-15-2003, 08:47 PM   #4
its a 1982 model...sorry about that and thanks for the tips. I may go and see it in the morning...
Old 08-15-2003, 10:02 PM   #5
drboyd's Avatar
1978 25' Tradewind
Here's another source for info...
http://www.vintageairstream.com/rr_t...on.html#trends
Old 08-16-2003, 04:57 AM   #6
Thanks for the advice and tips..Im going to take a look thiis morn.
Was this site instrumental in you buying your Airstream? jcanavera Community Polls 149 05-14-2018 08:14 PM
Buying Airstream, need help! jfaucett Our Community 33 08-03-2003 07:24 AM
Buying used Airstream dinoburb Buyer Guidelines 12 12-19-2002 02:31 PM
airstream! airstream! airstream! 83Excella Our Community 0 03-23-2002 10:37 PM
