Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 08-06-2006, 10:42 AM   #1
1982 31' Airstream310
Goose Creek , South Carolina
Broke Down on the Road in Sturgis SD
My Brother is on a trip Sturgis SD and Broke Down on the Road in his 1982 Air Stream, Powered by a 6 cylinder Turbo Isuzu 353 Diesel with a Chevy Turbo 350 Transition. He is hearing a lot of noise at an idle, but none under power. He has found the Flex plat is loose and can be moved over an 1” back and forth.
My request is, does any one have a Parts Break Down or an Illustration of that area between the engine and trany. We need to learn more as to what is going wrong in there and the part numbers of the “adapter” and “flex plate” so we can find the correct replacement part the first time. Thanks to all that may help us in our time of need!
rklies is offline   Reply With Quote
Old 08-06-2006, 01:19 PM   #2
Frank S
peoria , Illinois
Hi rkiles--I had a flex plate bolt drop out on a 1980's vintage Chevy van with the same transmission. The bolt made a lot of noise bouncing around in there. If I remember correctly there is a cover plate on the bottom which is easily removed, and when I removed it, the bolt dropped out. This gives you enough room to get in there with a wrench (open or box end) to replace the dropped out bolt (cause of the noise), and tighten up the rest. Didn't need any new parts. Good luck, and tell your brother to have a good time in Sturgis.--Frank S
Frank S is offline   Reply With Quote
Old 08-06-2006, 01:39 PM   #3
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
We hope by now that, with Frank's idea, your brother's rig is repaired and he's on his way to a great Sturgis rally. We've been to Sturgis once, when visiting the Black Hills, just before their Corvette Rally. Theh town was a filled up popping place then; can't imagine what it's like for the big one! Best wishes!~G
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Tivo on the road... Andy R Audio, Video & TV 3 04-18-2004 09:57 PM
Off The Road ALANSD On The Road... 5 07-22-2002 05:35 PM
On the road in VA ALANSD On The Road... 1 06-27-2002 09:51 AM
1985 310 found off road ViewRVs General Motorhome Topics 1 05-27-2002 12:15 PM
Survival supplies On the Road FrankR On The Road... 7 04-19-2002 01:54 PM
