08-03-2019, 10:19 AM
2019 27' Tommy Bahama
Ocean Pines
, Maryland
Blue Boy
My wife and I are interested in purchasing a Barker 42 gallon 4-WheelerTote Along. Although it is highly rated, the only issue I see is that the connection from the AS holding tanks are about the same level as the waste water input. Is that a show stopper for us?
08-03-2019, 10:23 AM
Sag Harbor
, New York
Could you please provide a link to the product?
08-03-2019, 10:25 AM
1993 34' Excella
Estancia
, New Mexico
The sewer hose will probably fill with black water but will siphon into the blue boy. When you are ready to dump just lift the hose to drain the residual. Use a short sewer hose. Another issue is the weight, about 300 pounds full.
08-04-2019, 07:16 AM
Ocean Pines
, Maryland
08-04-2019, 07:20 AM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
It makes it less than fun, but you can work around it.
08-12-2020, 02:56 PM
2020 27' International
Neptune Beach
Blue boy
I was just curious if you ended up buying the 42 gallon blue boy? We are thinking of the same and wondered if you were happy with it?
08-12-2020, 03:18 PM
Oswego
I have a very old two wheeler 22 gallon blue boy. The 4 wheeler models make 40 gallons doable. But both have height issues with AS low drain points. Some sites are fine, some are very difficult.
-Rich-
08-12-2020, 04:03 PM
1993 34' Excella
Estancia
, New Mexico
Keep in mind that a full 42 gallon blue boy will weigh about 300 pounds.
08-12-2020, 04:26 PM
Oswego
Right, but the 4 wheelers alleviate that issue quite a bit. I certainly wouldn't want more than my 22 gallon 2 wheeler.
-Rich-
08-12-2020, 04:56 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
42gal, 4 wheels, 300lb...does it have hitch and Michelin LT's to toe it to the dump?😂
08-12-2020, 05:03 PM
Oswego
Ppp hitch and teeny little LT michelins , but they quit making the size I need, so I'm going with RIBs
-Rich-
08-12-2020, 06:27 PM
2017 16' Sport
N/A
, N/A
Blue Boy
I need one of these, how do you get around the height issue. Thanks. Have you had issues with pneumatic tires?
08-12-2020, 08:34 PM
Oswego
My, very old, 22 gal 2 wheeler has solid tires. So, using an extra long hose can usually get me to an elevation that works. Sometimes ya just gotta fill the hose and work it like a slinky to work a half gallon to a gallon at a time. This is gray water exclusively, we can go the better part of 2 week on black and i cannot ever remember hauling black water since getting the AS with a 39 gallon tank.
A 90* elbow, helps a lot, if your fill port on the blue boy is on top.
-Rich-
08-12-2020, 09:47 PM
I'm In
, Kentucky
A long slinky with the blue boy downhill from the AS helps. You can also raise your stabilizers and lower the AS on the jack to give more elevation to the drains. You won't be able to empty the tanks but you will get quite a bit out. It pretty much fills our 15-gallon Tote-N-Stor 25607.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
08-12-2020, 09:52 PM
2007 27' Safari FB SE
NW Oregon in a nice spot
, Oregon
You are a far braver sole than I. Care to help the curious of us know why you want such a big one?
Good luck dealing with this one!!
