Old 06-23-2003, 05:49 PM   #1
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
Blobs of silicone on screws?
Was reading another posting here and silicone doesn't seem to be a good answer for sealing on Airstreams--vulcam or parbond preferred...
I have only washed my TT twice (it never rains here) but each time I have I noticed I "dislodged" a blob of what looks like silicone on the screws above the windows--in the rain gutter.
Should I be replacing this?
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 06-23-2003, 06:06 PM   #2
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
That's an interesting question, Kistler! After reading your post, I just went out and looked at the window gutters on my '94. They're all riveted. No screws. The crack is sealed with Vulkem or something similar.
Has Thor done something different, perhaps to cut production costs in later years?
I guess I'd check all of your window gutters. If they all came with 'blobs of silicone', I suppose it was for a reason and should be replaced. I've always avoided silicone like the plague on my Airstreams, but things change...
Roger
Old 06-23-2003, 07:10 PM   #3
norbert's Avatar
1993 30' Excella
chicagoland , north of cheddar curtain
Images: 24
silly silicone
I guess to find the answer you would have to take the factory tour... over the years in manufacturing silicone has become the answer to everthing...if they squirted some in the hole then shot the screw in... the blob would not be missed... if the blob dont fit you must aquit.... ...norby...
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 06-24-2003, 05:44 AM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
No screws on mine either....but on a different note, the wood screws on the inside upper cabs constantly unscrew while in transit. I took some wood glue on one and it didn't really hold. I took some silicone clear caulk and it now holds them in just fine.
Eric
Old 06-24-2003, 06:25 AM   #5
sjptak's Avatar
silicone. How did we ever get along without it? The last place I worked, a SS leg fell off of a SS sink table. The welder was sent up to weld the leg back on. The Hobart portable MIG wasn't set up for SS (he would've had to change the wire), he didn't feel like carrying the unit or the gas, IOW, he was just plain lazy. He brought in the caulking gun, squirted the top of the leg and put it in place. As far as I know, its still there. That was 6 mos ago.
Stan and the Lou
Together Forever
BTW, that's MaryLou
sjptak is offline   Reply With Quote
Old 06-24-2003, 07:21 AM   #6
Aluminut
2004 25' Safari
. , Illinois
I hear ya. In my car, the factory placed the trans cooler right behind the bumper so it didn't get good or any airflow. I cut a square out of the front bumper cover to get some airflow to it. I painted some gutter mesh and installed it to protect the cooler from rocks, etc.
Well as you might have guessed, I attached it using silicone! Works like a charm!
Silicone is great stuff!
Eric
Old 06-24-2003, 07:28 AM   #7
Kistler's Avatar
2002 25' Classic
OK, I will have to go look; maybe they are rivets but in any case shall I try to "re-blob" with silicone. I have some parbond and vulcam on hand by the way
Kistler & Brenda
2002 Classic 25'
Old 06-24-2003, 07:36 AM   #8
Aluminut
2004 25' Safari
. , Illinois
I think you should use the Vulcam, I think we were just talking shop about how much we like using silicone for other odds and ends. If you have a leak right now and it is going to rain, then a bit of silicone to help protect it or some tape until you can get the Vulcam in might be good, but you will have to make sure you get all of the silicone out and or tape glue otherwise I don't think it will bond very well. If no moisture is in it's future, I'd just wait for the Vulcam.
Just my .02.
Eric
Old 06-24-2003, 07:44 AM   #9
norbert's Avatar
1993 30' Excella
Images: 24
rtv silicone
used to be in the hvac business...the manufacturer used to build heat exchangers and glue them together....that red stuff is awesome....norby
Old 06-24-2003, 08:06 AM   #10
Kistler's Avatar
2002 25' Classic
Believe me it is dry here I will clean carefully and use vulcam. I don't think the awesome "red stuff" will go well with my color scheme
Do you think it will bond in smoke? The TT is in covered storage at the base of the Catalina Mtns. I am thinking of bringing her home even though the "controlled community" patrol will report me. We are surrounded by houses with tile roofs and rock yards.
Kistler
silicone removal sibyrnes Cleaning, Stripping & Polishing 3 06-01-2005 07:52 AM
steel or stainles steel screws remcolent Ribs, Skins & Rivets 11 03-30-2004 06:54 AM
removing corroded belly pan screws Cruiser Belly Pans & Banana Wraps 2 09-14-2003 12:17 PM
Rusty screws in side windows (galvanized) Orland Dewey Airstream Motorhome Forums 4 06-17-2003 08:42 PM
Clutch head screws Zed2 Windows & Screens 4 08-23-2002 05:16 PM
