Old 08-27-2003, 05:18 AM   #1
Vroom
Richard Vroom's Avatar
Mahone Bay
Images: 14
Black Water
Every few days we get black water out of the hot water tap for a minute. I have a new circuit board on the hot water heater. I have had trouble with the water heater in the past but it runs well now. I cannot understand where the black is coming from??
Sincerely,
Richard
Richard Vroom is offline   Reply With Quote
Old 08-27-2003, 06:09 AM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Probably the anode rod is shot, and needs to be replaced.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 09-02-2003, 06:53 AM   #3
Vroom
Mahone Bay
Images: 14
Black Water
I have an Atworod water heater and it has no anode at all, just a metal plug???
Richard
Old 09-02-2003, 07:06 AM   #4
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Is it coming from all the faucits or just the Galley? Most units have a water filter under the galley sink. Might want to inspect it.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 09-02-2003, 07:13 AM   #5
Vroom
Mahone Bay
Images: 14
It is coming only in the galley sink after a night heating hot water. It seems to be only from the hot water sid eof the water system. It is black like chimney sut and lasts about 30 seconds when we turn on the water in the morning. My dealer thinks I should replace the hot water tank for mega bucks.
Richard
Old 09-02-2003, 11:30 AM   #6
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Could be mold
It is possible that you've got a mold infestation somewhere in the hot water system. We had this happen in a house we rented -- occasional blobs of black gunk would come out with the water.
Before you replace the tank, try "shocking" the system with a chlorine bleach/water mix (maybe 2-4% bleach). Run the hot water till you are sure the tank is full of the mix, then let it sit a little while. Run the faucets till the bleach smell is gone.
That should kill anything living in the tank, but if it is mold, you'll find bits of it coming out periodically afterward. You might still end up replacing the hot water heater.
rluhr is offline   Reply With Quote
Old 09-03-2003, 07:19 PM   #7
Vroom
Mahone Bay
Images: 14
Black Water
I think I have found the problem. It was not the hot water but the water filter. When removed, it was full of black sutty water. I have replaced it and also added an anode to my hot water system. Hope this does it. Thanks for your help.
Richard
Black Water Tank David Hall Waste Systems, Tanks & Totes 3 12-28-2003 07:24 PM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
