Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 02-18-2003, 09:15 AM   #1
Black Tank Flush System
Can a black tank flush system be purchased later or must it be ordered at the time of purchase.
If it can be purchased later, how much will it cost. We are buying the '03 Bambi.
Has anyone added a sattelite radio system? Can the sattelite radio purchased for the car be removed and put into the trailer? Obviously, each would have to have a mounted system and antenna but at least not two radios.
Ed L is offline   Reply With Quote
Old 02-19-2003, 06:56 AM   #2
1996 30' Excella
Brighton , Michigan
The black tank flush must be ordered with the trailer as it is built into the tank. I have had two trailers without the flush and never had a problem, however my current trailer has the flush and it is much easier to clean the tank out and I would not buy a trailer without it.
apple 1 is offline   Reply With Quote
Old 02-19-2003, 07:20 AM   #3
1999 25' Safari
Edina , Minnesota
I just asked my local A/S dealer this same question. The parts are about $50 and the labor to remove the aluminum belly and install the kit are estimated at 4 hours labor. Get someone who has worked on A/S trailers as the other shops seem clueless how to deal with the belly pan.
JaceBeck is offline   Reply With Quote
Old 02-19-2003, 07:28 AM   #4
1999 25' Safari
Edina , Minnesota
Labor rate at my local dealer...$82. 00 per hour
Old 02-19-2003, 07:37 AM   #5
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
What you are saying is ...
you had better be pretty flush to install a flush.
I have never had problems without it installed, but I would order it on a new trailer.
John W. Irwin
WBCCI #9632
Old 02-19-2003, 07:51 AM   #6
The consensus seems to be that we better add the black tank flush system. I appreciate everyones remarks and, I will get the Bambi upgrades but I think that I will try to get the dealer down a bit on his price since individually priced the items are less than the package price that the dealer is asking.
Thanks Ed
Old 02-19-2003, 08:36 AM   #7
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
The other thing I like is the heat pump. If it's above 30-40 degrees, and you aren't paying separately for electricity at the site, it saves you money on propane. Mine automatically turns off and fires the furnace up when it gets too cold outside for the heat pump... which also when you need the furnace to keep the tanks from freezing. It also switches back to the heat pump when it warms up outside.
Maurice
RoadKingMoe is offline   Reply With Quote
Black water tank with septic system rfield54 Waste Systems, Tanks & Totes 5 06-02-2021 07:13 PM
Recent Bambi owners wanted! rluhr 1997 - 2004 Bambi 82 09-01-2009 08:55 PM
Black tank flush.... drboyd Waste Systems, Tanks & Totes 11 08-01-2003 07:40 AM
How to add a b/tank flush system inthwind Waste Systems, Tanks & Totes 2 06-25-2003 09:59 AM
Easiest way to flush black tank? JLD Waste Systems, Tanks & Totes 10 02-19-2003 07:16 PM
