Old 11-20-2014, 10:56 PM   #15
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Educational Behaviors
Originally Posted by cwf View Post
Oh... close the toilet valve as much as possible .... to reduce 'blow back'... DAMHIK...
No worries, you won't make that mistake twice!
SeeMore is offline   Reply With Quote
Old 11-21-2014, 11:33 AM   #16
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I have a washout device which attaches to a hose. You stick it inside the black tank thru the toilet flush valve... turn on the water and 'spin' the device so that it sprays all around.
Perhaps this will allow you to 'direct' a blast at the pile...oh.. close the toilet valve as much as possible .... to reduce 'blow back'... DAMHIK...
I had one of those with the other trailer. It look like a wand with a pressure nozzle on the business end. Seems like I bought it at Walmart. Now I use the built-in black tank flush.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-21-2014, 12:50 PM   #17
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Our Overlander when we first got it the holding tank was about full and had been that way for a long time and frozen when we first got our trailer.. I went ahead and pulled it home that way thinking too myself,, what a jerk..
I worried for weeks about it but once the weather warmed up nothing was broken..
I think if it was mine,, I would go ahead and pour a gallon of RV antifreeze in the holding tank just to make sure nothing freezes hard.. Don't forget to reach your arm inside and get it all mixed up.. ( just kidding,,)
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 11-21-2014, 06:21 PM   #18
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I ain't going to look in mine!!!
Old 11-22-2014, 06:18 AM   #19
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Maybe you could trade the AS for a newer one....
Old 11-22-2014, 08:06 AM   #20
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
So far we have never had the "mounding" problem. And the BW tank looks clean on inspection.
I always try to dump the tanks upon arrival. That way everything has been stirred up from the days travel.
TG Twinkie is online now   Reply With Quote
Old 11-22-2014, 08:40 AM   #21
HowieE's Avatar
Princeton , New Jersey
Images: 12
Progress! Is it always moving forward?
I just replaced the toilet in my trailer and this discussion has caused me to think about it. The new toilets, by the design of the bowl and the activation assembly, do not use any where as much water. One would consider this as progress until you are faced with the topic of this discussion.
Historically "mounding" was a problem of trailer that had the toilet, mostly SOBs, on the curb side of the trailer, or the high side of the tank. The old adage "Sxxx flowing down hill" is not really true it needs water to get things started and to maintain the trip. So called progress has now given us a chance to share this problem. The water we saved in the usage will now be used to move things along.
2004 Excursion 4x4
Custom grey and black tank fabricators/suppliers and advice!! A-Merry-Can Waste Systems, Tanks & Totes 38 07-06-2017 06:37 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Leak near black tank sensor. Help please. nesvt Waste Systems, Tanks & Totes 11 09-29-2011 12:13 PM
Help!!! Fresh water tank/ black tank meredith Fresh Water Systems 6 09-01-2011 11:51 PM
Toilet Union to Black Tank Advice PLEASE DKDarrow Waste Systems, Tanks & Totes 5 06-24-2008 01:12 PM
