Old 09-08-2005, 08:36 AM   #1
Bit tha' bullet!
I went out and bought a 1999 35' diesel Cutter. They pulled all the stops when they put this thing together, wow! ....Quick question, how much propane does a fridge normally go through when not running 110ac? Is it pretty efficient running on gas? It is going to be a couple of months before It is plugged up at a community.
urbanextreme is offline   Reply With Quote
Old 09-08-2005, 10:23 AM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Congrats on your new purchase! What model/size is the fridge?
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 09-09-2005, 03:58 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Urbanextreme,
Those are nice rigs we looked at one yesterday, but I am going to stay vintage for now...besides I "saved" $120k by not buying The fridges are very frugal on LP, if you have a full tank you should be fine, I have run my popup fridge for over a month on a 20# tank and still had some left over. However, the fridge does use 12volt power to run the controller, so make sure your batteries are topped up. Does your cutter have the Solar Panel option? If so, you are good to go.
Aaron
WBCCI #XXXX AIR #2495
Old 09-09-2005, 05:51 AM   #4
scf31's Avatar
1977 25' Caravanner
Jeffersonville , Kentucky
Congrats on the M/H ,,,, But does the fridge on my 77 model need 12v to run ???
scf31 is offline   Reply With Quote
Old 09-09-2005, 06:10 AM   #5
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
It depends.......
If it is the original fridge, no. If it has been replaced with a fridge that has lit buttons across the top, or no pilot(electric ignition), then yes.
Easy way to answer the question is with a question. Do you have to light a pilot light?
The 12 volt answer is the opposite of the answer to the above question.
OR
Do you have 2 knobs and a button at the base of the refer inside the door?
Same rule applies, yes means you do not need 12 volts to run.
Confused??
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 09-09-2005, 01:47 PM   #6
I have the solar panel. I don't know the wattage, but it looks to be a small size panel on the roof.
Old 09-12-2005, 11:28 AM   #7
I did find out the solar panel is only 10 watt, barely enough to cover parasitic draw of radio memory.
Old 09-12-2005, 11:30 AM   #8
I was reading the book on the fridge and it says it has a limp mode, but it doesn't stay on if I switch the power completly off. Oh well, I'll figure something out.
Trailer names paul k Our Community 649 05-24-2017 11:50 AM
AirstreamForums.com Member Sticker? Andy R Our Community 171 06-08-2007 10:12 AM
a bit of Wally Byam history striker Link Archive 0 03-29-2003 10:06 PM
International Tow Vehicle Hubba Our Community 18 10-30-2002 11:56 PM
Rolite or Nuvite? What did you decide? airstreamcaravel Cleaning, Stripping & Polishing 31 10-18-2002 07:14 AM
