Old 06-09-2004, 05:33 PM   #1
Smile Bicycles and the Bambi
We have been enjoying our 19' Bambi 2004 since December. Our towing vehicle is a 97 Suburban. The problem is how to transport our bicycles. The rear clearance between the Bambi and the Burb does not accommadate three bikes. A roof rack is too difficult to access. The best solution so far is to pack the bikes in the back of the burb with the 3rd seat removed. Has anyone transported bikes inside the Bambi? Has anyone attached a bike rake to a Bambi?
Thanks, Carol from Miami
bonnercaw is offline   Reply With Quote
Old 06-09-2004, 05:44 PM   #2
How about a bike rack attached to the front of the 'burb. I've seen some that looked good, some not so good. It would also reduce visibility a small amount, but you would always know if they get loose. Good Luck! David
davja is offline   Reply With Quote
Old 06-09-2004, 06:55 PM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Putting any extra weight on the rear of an Airstream, such as a bike rack, is not recommended. Since you have a (relatively) small, lightweight trailer, you may want to look at a combination hitch head/bike rack for the "burb. It will put the tongue weight further back, but it is not a sovereign, so it may work.
You can also mount a front rack on the tow vehicle, or maybe even place the bikes in the trailer. If you are worried about grease and dirt from them, an old blanket will protect the inside. We regularly haul two adult size beach cruiser bikes in our 20' trailer, with no problem.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 06-10-2004, 05:12 AM   #4
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
I wonder if Airstream will get into the "Toy Box" market and make a model that can carry bikes, motorcycles, ATV's etc.
rseagle is offline   Reply With Quote
Old 06-10-2004, 06:44 AM   #5
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
All they need to do is take the 34 foot with slide, replace the slide with barn doors and put industrial flooring with tie downs in the front lounge. The chassis should be able to handle the extra weight without the slide and not need much in the way of modification.
I bet if someone went to the custom products group it could be done.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 06-10-2004, 07:05 AM   #6
87MH's Avatar
1978 31' Sovereign
Images: 292
Front End Receiver
Install a standard 2" towing receiver on the front end of the 'burb. There are many bike racks available that would fit a standard receiver, and you could use them on the back end when not towing.
Another advantage of a receiver on the front end is the ability to manuever a trailer with much greater agility with a ball inserted into the front receiver.
I installed a front ball receiver on all of my previous Pickups. Sure was handy when you needed it. With a front end receiver, any other "extra" you want could be inserted into the front end (cooler carrier, boat lift, wheel chair hoist, etc), and do double duty for the back receiver when necessary. Don't know the serviceability of the engine in the 'burb from ground level, but a "front step" for my Ford Pickups was greatly appreciated.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 06-10-2004, 08:12 AM   #7
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
The birth of the new country Airstream.
I hope the put the "Chew Mail Pouch Tobbaco" artwork on the barn doors!
