Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 01-22-2003, 10:57 AM   #1
Creampuff
Creampuff's Avatar
2022 27' Flying Cloud
2016 25' International
Airstream - Other
Malibu , California
Images: 60
Bellypan Rivet Question
I dropped a portion of my bellypan for a frame repair and now want to do the button-up.Here's the problem-the seams are covered with heavy guage alum.straps about 1' wide and then rivetted with large pop-rivits that have a head approx.3/4 'in width and a shaft size like an Olympic.I am lead to believe this is a previous owner upgrade.Is this correct?The system is great and I just want to restore what I took out -problem is I can't find a source of the large fasteners.
Anyone know where??
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 01-22-2003, 04:00 PM   #2
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
i got some from jackson center , your local AS dealer should be able to supply LOL
al
wb13798 is offline   Reply With Quote
Old 01-22-2003, 04:06 PM   #3
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Olympic rivets are 5/32, at Home depot you can buy 3/16 medium or large aluminum pop rivets which would be 1/32 bigger than olympics. They don't have a 3/4" head, but they are very strong rivets and they "take" real well.
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 01-22-2003, 05:33 PM   #4
Chas's Avatar
Images: 22
Olympic rivets are a waste of money if you are going to use them on the bellyskin. You can find 3/16' standard rivets at any good fastener supply which are also available with a larger head about the size of a dime, which is good if you have places where the skin has pulled loose from a good rivet.
Chas
Chas is offline   Reply With Quote
Old 01-22-2003, 05:40 PM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
washers?
how about just useing good heavy duty rivets as chas suggested, and some fender washers?
john
Old 01-22-2003, 05:57 PM   #6
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Chas
Where does one find those dime-sized headed rivets? Specialty store?
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 01-22-2003, 06:27 PM   #7
Chas's Avatar
Images: 22
fingas' do the walkin'
fly fshr,
Look in your yellow pages under fasteners, bolts, screws. You will be surprised to see how many different styles of rivets are available. I am still looking for one that carries the olympic rivets though, most of them don't even know what they are.
Chas
Old 01-22-2003, 06:42 PM   #8
LOST , Hawaii
Olympic rivets or Fastenal (if there is one local to you) will have them or get them next day.
John
74Argosy24MH is offline   Reply With Quote
Olympic rivet removal and installation PeterH-350LE Ribs, Skins & Rivets 90 11-07-2012 01:34 PM
rivet tools maznblu Ribs, Skins & Rivets 12 05-31-2006 05:51 PM
Rivet holes and Door Latches JimC Doors & Locks 1 10-17-2003 10:12 AM
Rivet Question JMoy Ribs, Skins & Rivets 4 09-27-2003 07:43 AM
