Old 09-30-2013, 11:04 AM   #1
Stream Weaver
romakdaddy's Avatar
1989 37' Airstream 370
pamplico , South Carolina
Send a message via Skype™ to romakdaddy
bedroom fan
not sure if this is the proper place but im trying to find parts or a replacement for the bedroom fan on my 89 370 its the one that the cover goes straight up and down.
romakdaddy is offline   Reply With Quote
Old 09-30-2013, 01:04 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
What parts do you need?
Try an Airstream dealer or Inland RV. If parts are no longer available Fantastik Vent and Maxx Air are both excellent replacement units.
Old 10-01-2013, 07:57 AM   #3
Stream Weaver
romakdaddy's Avatar
the whole fan assembly is just worn out its hard to get up and down and the cover is dented and has sealer all over it like it may have leaked...ill post a pic I took as soon as I can
Old 10-10-2013, 08:19 AM   #4
Stream Weaver
romakdaddy's Avatar
here's what the cover looks like...
Old 10-10-2013, 09:24 AM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
The cover is definitely salvageable. You should be able to find a replacement motor. Silicone spray may free up the sticky mechanism. The question is do you want to fix it or replace it?
Old 10-10-2013, 09:29 AM   #6
Stream Weaver
romakdaddy's Avatar
the fan spins(unless its fully closed due to the cover being caved in) the seal is shot and it does go up and down but its stiff and clunky. is there a better replacement or would I be better off fixing this old one up?
Old 10-10-2013, 10:50 AM   #7
Lumatic's Avatar
1993 34' Excella
Images: 16
If you replace it see post 2 above. These units come with different levels of bells and whistles. All of them are three speed reversible fans that are much quieter and move a lot more air than the oem fans. The next step up is a thermostatically controlled fan, which I have for leaving pets in the trailer. The ultimate are fans that automatically shut when it rains and with a remote control so you don't have to walk across your trailer to turn it on. But it's still a camper and people have different ideas of "roughing it".
You should know you will have to do some minor cutting to the ceilng and roof to get the fan to fit. Be careful not to cut into the wiring harness which is also up there. No big deal.
The only reason I see for keeping the original is if you are a vintage airstream purist or don't have the $200 + or - for the aftermarket unit.
Old 10-10-2013, 11:02 AM   #8
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
Oh...I saw the thread title, Bedroom Fan, and I thought Oh yeah, I'm a bedroom fan, and then I clicked it, and .....well.....never mind.
Carry on.
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
