Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 11-27-2004, 04:42 PM   #1
Kistler's Avatar
Profile:  2002 25' Classic
Oro Valley , Arizona
Battery replacement..have SRM27 Interstate
OK, the trailer is a 2002, who knows how old the batteries really are....have those punched out numbers and year -- March 2004...and I think they have done their very best
I do not need "cranking power" and have been advised that these Interstate batterties are not "truly" deep cycle...
OK, what do I buy, people? I wouldn't say that money don't matter but what is a good value?
Kistler
Kistler is offline   Reply With Quote
Old 11-27-2004, 05:00 PM   #2
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
Greetings Kistler!
I follow two different approaches to the batteries that I utilize in my coaches. For the Overlander, I utilize a very high quality AGM RV/Marine Deep Cycle battery because it has an advanced charging system (solar with inverter/charger installed by AJL Solar) - - these batteries were very costly, but are now in their fourth season showing no evidence of age. For the Minuet with its Magnatec converter (installed two years ago), I utilize a Die Hard RV/Marine Deep Cycle battery or its equivalent as the Magnatec has demonstrated its propensity to boil the battery (by shopping for an early season sale, I can often obtain one of these low-end batteries for around $60). I am happy to get one full season from the battery under those conditions and ecstatic when the battery makes it two seasons as the current battery just completed its second season.
Good luck with your battery quandry!
Kevin
Kevin D. Allen
AIR #827
Old 11-27-2004, 06:14 PM   #3
Profile:
To understand your choice, you could go here: http://www.phrannie.org/battery.html
but if you want a quick recommendation for an inexpensive set-up that will allow the occasional night of boondocking, buy two group 27 "marine/deep cycling" batteries from Wal-Mart. (note the inverted commas) You might like to look on the tops and get two from the same batch number. I also take my digital voltmeter, and choose the two nearest in voltage from the same batch number, but you don't need to bother with that. If you also plug them into a "battery minder" when away from the trailer for more than a few weeks, they should prove an economical solution. They work for me. Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 11-27-2004, 10:41 PM   #4
silverback's Avatar
Profile:  2006 28' Safari SE
Phoenix , Arizona
Golf cart batteries...
When we were first looking at Airstreams, we visited a couple in Scottsdale selling a slightly used 02 Bambi. The owner had replaced the stock battery (not plural if I recall correctly) with golf cart batteries. He stated they were true deep cycle. That's as much as I remember.
Ken
4CU Charter Member
2004 Silverado 2500 HD D/A
Honda EU2000i
Hensley Arrow
KE7DUI
silverback is offline   Reply With Quote
Battery Location uwe 1970-79 Tradewind 22 09-04-2003 08:44 PM
deep cycle battery replacement 26Argosy.ca Electrical - Systems, Generators, Batteries & Solar 6 01-02-2003 06:19 AM
Battery Dead - Again & Again eraffety Airstream Motorhome Forums 10 11-02-2002 12:03 AM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 03:58 PM
Extra Battery Placement JaceBeck 1999 Safari 16 10-02-2002 02:03 PM
