If you have to leave your A/S in storage as I do, the exposed battery is a prime target for thieves. I figured an $80 battery was worth a little security.
I pop-riveted 3 "footman's loops" to the battery box; on each of the forward and rear sides and in the center of the top and through large washers on the inside of the box. I then swaged thimbles on a piece of aircraft cable, making it just long enough to accept the hoop of a padlock. The cable runs through the loops and under the crossmembers of the tongue.
The cable can be cut with some effort, but no one can just pick up my battery and walk away with it.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
The photos are all taken with a Sony DSC-S70 CyberShot and then resized and adjusted for brightness and contrast with PhotoShop Elements. I take all shots at 1600x1200 so they have good clarity when reduced for the web.
John W. Irwin
I hadn't given it much thought until I saw your pic but I really like the idea of an exposed battery compartment. An enclosed battery compartment, while neat in exterior apperance and harder to steal, often leads to a neglected battery. Out of site, out of mind. Having it right there where you have to look at it while hitching up, should remind one to check the darn thing once in awhile! Looks good.
Randy
Overlander,
I've only been fulltiming since Feb 2002 and when I 1st got the trailer I checked everything and the batteries were new and in good condition.
As I was traveling out west in April, I had some cold nights in WY, 15 degrees at night. One night I forget to turn the converter back on prior to going to bed and ran the batteries down. When I finally checked them out in B.C., one was completely dry. So I learnt a $80 lesson about checking the batteries. I check them monthly now!
John
While it probably isn't as much of a problem in the south, an exposed battery is a cold battery... and cold batteries don't provide as much output. I like having the battery compartments in the living area of the trailer. On cold evenings we open the drawar below the couch so more heat can get back to them.
An inside battery is great on a bigger trailer, but on a 22' trailer, whatever comes in, something else has to go out.
I see 2 reasons for the battery on the International A-frame:
1: Space: This is not a wide body trailer and there is only about 19' of shell to pack things into. The AS has just sufficient storage to make it more than a weekender.
2: Balance: With the bathroom galley, black, and gray tanks behind the axle, the heavy battery way out on the tiongue provides a good counterbalance.
John W. Irwin
