Old 05-06-2009, 05:49 PM   #1
2006 19' International CCD
Philadelphia , Pennsylvania
Battery Charged but Electric Items Only Working When Plugged in..help?!?!.
Hello All,
Getting ready to shove off in the am and am experiencing an odd problem.
my battery was stored properly all winter on a tender.
looks to be fully charged. It seemed to power my jack fine but the electricity in the unit is not powering up.
Working fine when I plug her in.
Any ideas? I'm sure it is something silly...but i'm a newbie....so still learning.
Thanks!!!!
ericwarren is offline   Reply With Quote
Old 05-06-2009, 06:03 PM   #2
Ottawa , ON
There's a switch in the electrical system, "Storage"and "Run", or something like that, isn't there?
Sorry, I'm having a CRS moment, but I believe that you need to switch the electrical system to active duty, so to speak.
Have a look at your control panel, or on the charge controller. There is, I believe, a circuit that give a different charge pattern to the battery for off-season storage.
Hopefully, someone that knows what they are talking about will show up soon.
Old 05-06-2009, 06:08 PM   #3
i've tried toggling the store/use switch and doesnt seem to do anything but make a click sound....
Old 05-06-2009, 06:17 PM   #4
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The relay that controls that circuit could be bad.
Old 05-06-2009, 06:36 PM   #5
lynn's Avatar
The battery needs to be at least 10.4volts to operate the switch.But you indicated that it was charged so it could be the relay.
lynn is offline   Reply With Quote
Old 05-06-2009, 06:50 PM   #6
any way to test? need to fix by tomorrow am
thx!
Old 05-06-2009, 07:08 PM   #7
RossFam05BH's Avatar
2005 30' Safari
Pfafftown , North Carolina
Even if the trailer is connected to shore power, the toggle switch on the battery disconnect board has to be trigger in the use position to charge the batteries. The red LED being on does not indicate the batteries being charged. If you can still run the electric jack, you should still have enough power to engage battery connection with the solenoid. I hope this helps before tomorrow's run.
BTW, all winter I thought the batteries would charge automatically when connected to shore power. Dead batteries convinced me to add some LEDS to the battery disconnect panel to show the state of the solenoid when connected to shore power. See this thread and our post.
Bye
Paul
2005 30' Bunkhouse "Nedapedalua"
2002 Ford Excursion 7.3L Diesel 2WD
WBCCI #5182
AIR # 6050
RossFam05BH is offline   Reply With Quote
Old 05-06-2009, 08:13 PM   #8
thanks...
definitely seems like the solenoid. i hooked the meeter up and am getting power on one side but not the other.
not sure if there is a band-aid for this until i can get a replacement...dont think ill be able to track one down in the am before we leave.
thanks!!!
Old 05-06-2009, 09:42 PM   #9
Ottawa , ON
Well, I've never see the solenoid you're talking about, but the ones I have used had a clear plastic top which can be removed, giving access to the terminals.
If that's what yours is, after disconnecting any power source connected to it, remove the clear top, and take some fine sandpaper and rub it back and forth between the terminals. If the failure cause is corrosion, that should get you in good enough shape to get going and keep you going for a good while.
Also, make sure the spring isn't gone and that there is some tension in the reed of the relay.
I would also take a meter to the batteries and see what voltage they measure. Let us know?
Old 05-07-2009, 05:14 AM   #10
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Eric,
One of our camping friends had a similar problem in a bunk house model. I am not sure if the store / charge switch is the same as your but it seems the large rocker switch in his unit has a "detent". Just throwing the switch is not enough, he had to depress the switch to the next detent after throwing the switch to get it to engage. I hope you can get the problem recitified before hitting the road.
I had an '85 chevy diesel with dual tanks and the switch between tanks was the same way. Moving the switch to the second tank would activate the fuel gauge sensor but not the solenoid that controlled the valve between the two tanks. After throwing the switch you had to press it further for a few seconds to get the valve solenoid to engage.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 05-07-2009, 07:13 AM   #11
Well Preserved
1993 21' Sovereign
The one in his trailer is a relay that looks similar to an old Ford starter solenoid.
Old 05-07-2009, 08:04 AM   #12
ok..we are up and running.
i took it apart, cleaned the contacts and re-set the spring.
seems to be working
i ordered a back-up, should this happen again.
thanks for your help, really appreciate it!
Old 05-07-2009, 08:24 AM   #13
Ottawa , ON
yay!
Have a nice trip!
Plugged or Un-plugged in the Driveway clancy_boy Winterizing, Storage, Carports & Covers 25 10-02-2017 01:14 PM
Charging Battery While Plugged in to Shore Power Kevin245 Batteries, Univolts, Converters & Inverters 2 12-29-2007 01:10 PM
Electric Brakes - Are they working? bevman Brakes & Brake Controllers 12 08-25-2007 02:47 PM
Remove all Propane items...and replace with all electric leefields LP Gas, Piping, Tanks & Regulators 19 02-20-2006 05:57 PM
electric humming when it's not plugged in AnnZ3 Electrical - Systems, Generators, Batteries & Solar 4 10-27-2004 06:27 AM
