Old 12-17-2007, 06:18 PM   #1
RichardT's Avatar
Bad advice
How to clean airstream travel trailer? - Yahoo! Answers shows the following question and answer on Yahoo answers.
Don't follow the advise given.
what products to clean exterior with and how due to shape of airstream?
Best Answer - Chosen by Voters
OK, depends on how cruddy it is..........and how old.........most likely U gonna get wet doing it. If it average cruddy I recommend go to a good hardware store and buy something called "Tri Sodium Phosphate" TSP for short. It comes in a bag as a dry powder something like salt. U mix it with water and scrub the whole surface of the trailer with it. Depending how strong U mix it it will remove everything from bugs and tree sap to enamel paint. Wear clothes U don't want anymore! Bathe well immediately as it is somewhat caustic. Rinse the trailer well. If that don't do it then U need to go to a paint store and get a product called "Metal Etch" That's a mild acid and protective clothing is necessary. Neither product will make yer airstream look brand new without applying a coat of clear laquer or varnish after cleaning. Rinsing window gaskets and seals is a must after using either product. I used a sponge mop and tsp on mine and never bothered with clear coat........looked fine with normal washing for abt 10 yrs after..........If the blue stripes are faded or oxydised U nay need to repaint them.
RichardT is offline   Reply With Quote
Old 12-17-2007, 06:23 PM   #2
Images: 59
. . . written by a Yahoo, for Yahoo.
Old 12-17-2007, 06:24 PM   #3
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Now you tell me...
pmclemore is offline   Reply With Quote
Old 12-17-2007, 06:50 PM   #4
And that same "mild" acid also gets under the rivets heads, and causes long term water leaks.
Where are those water leaks?
Under the rivet heads where you can't see them.
We have replaced thousands of rivets, to solve that problem, and in rare cases, had to replace the sheet metal as well, since the oxidized holes around the rivet shanks, where huge.
No acid to the aluminum exterior, "EVER."
Old 12-17-2007, 07:01 PM   #5
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Any way to write a correction there?
Like much of the internet, garbage in - garbage out. Use with caution, etc.
Dave
Fyrzowt is offline   Reply With Quote
Old 12-17-2007, 10:22 PM   #6
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Yet another reason why the best Airstream answers are found right here.
www.nesa.org
Air No. 6427
how bad is too bad a dent? prairieschooner Exterior Restoration Forum 26 07-21-2010 02:40 PM
Bad as it looks? sumsmug Repairing/Replacing Floor &/or Frame 4 09-17-2007 10:44 AM
What is this...can it be bad?? dragonnfly Electrical - Systems, Generators, Batteries & Solar 11 05-28-2006 03:41 PM
Bad Bad Things... (a new 454 Engine?) pillageTHENburn Mechanics Corner - Engines, Transmission & More... 24 12-19-2005 01:49 PM
How bad have you got it? 69Ambassador Our Community 6 10-25-2003 05:08 PM
