Old 07-23-2016, 08:01 PM   #1
Sioux Falls , South Dakota
Awning questions
As I look at the Classifieds, dreaming of when we can have a 34' Airstream, I noticed something. Our Foretravel MH has Zip-Dee awnings, as do Airstreams. However, our coach has individual awnings over the windows in the living room area, dining room area, and bedroom (front to back on the curb side). We also have a large patio awning there. It looks like Airstreams only have the patio awning and bedroom awning on the curb side - no individual window awnings. True?
When parked, I generally have all of the individual window awnings out unless really high winds are expected. The patio awning goes out as needed when we are at the coach and winds are not too high. If the Airstream only has the patio awning, do you do as we do and put it out only when you are there are the winds aren't too strong, or do you have it out all the time?
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 07-23-2016, 08:25 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Not necessarly. I have seen many Airstreams with individual awnings. Personally I like the longer ones. They provide a lot more cooling shade.
MICHAEL
Old 07-24-2016, 08:52 AM   #3
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
My '15 FC 27 FB has awnings all around.
Mike
Caffeinated is offline   Reply With Quote
Old 09-04-2016, 08:17 PM   #4
1973 29' Ambassador
Russellville , Arkansas
Identify Awning
Can anyone identify what type of awing this is on my 1972 ambassador land yacht. Also is there directions on how to raise it? We are gonna open it to inspect the condition and I don't want to damage it by doing it improperly. I have tried to search for a demo but because I am not sure of what type and the video all seem to be for newer ones I could use some help. Click image for larger version
amberlink is offline   Reply With Quote
Old 09-04-2016, 09:54 PM   #5
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
Hard to tell but from this distance and not with a close up picture the awning looks like a Carefree. The bent curved arms indicate that is what it is.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 09-05-2016, 01:39 AM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Our 34 Excella has shades for all. Curb side, stern, a long one which covers from galley kitchen window forward (bow) on the street(port) side.
The front has the center window protection which can be opened for shade or to open the glass.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-05-2016, 11:56 AM   #7
amberlink, my suggestion would be to have several people and a couple of ladders available when you try to deploy the awning for the first time. Take it slow and don't try to force anything. Yes, you might have to put some effort into getting things moving, but if it won't move at all don't try to force it to move. There is a powerful spring in the tube, and severe injuries are possible if it breaks or suddenly retracts.
You should have some resistance when you open it, as the spring inside the tube will try to retract it. If not, you may have to roll the awning up by hand (hence the need for extra people and ladders). Most awnings will have a strap hanging down that you hook and pull to open them. If you can't see that strap it might be wrapped up inside somewhere, or it may have rotted off. If that's the case you will have to unroll the awning by hand. Again, extra hands and ladders will be helpful.
Be safe.
TAC SD-6
AIR 54240
Old 09-05-2016, 12:13 PM   #8
1976 31' Sovereign
Oswego , Illinois
The arms look like angled top to bottom, that means not installed properly, also can not tell by enlarged pic. if fabric is torn but does not look rite at both ends. To extend if no pull strap, have person pull evenly both arms at same time, if no damage or pull strap can pur. new They slide into groove in tube when open. Agree looks like care free awning as What was basic awning at time of year trailer manf. Parts are still av. except for curved arms as care free only makes strait arms now. Post above is correct but if pulling on arms stand on ground not ladders, just reach about head high to pull. Make sure latch is released on arms [shown in pic. even with bottom of rear side window should be one same location front window.] If can not release push in on arms will release pressure letting latch slide up freeing arms to pull open
Old 09-05-2016, 12:25 PM   #9
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Airstreams have basically whatever awnings the original purchaser choose to put on them. Some times the awnings are added by the dealer. Our trailers have the patio awning and then a long awning on the curb side and a short awning on the rear. We pretty much leave the curb side and the rear awning out when camped. Keeps some of the sun off the side of the trailer and we can leave the windows open. We put the patio awning out and put it up if there is a threat of a storm. At the fixed camp we leave the patio awning out more in worse weather but use tie downs at the front.
I know some people who have a pretty nice 34' for sale. Check the adds at TCPC and see if it is listed.
Old 09-05-2016, 03:31 PM   #10
1973 29' Ambassador
Awning not installed correctly
So you are saying it doesn't look like it is installed correctly? Is there directions on how to install one correctly anywhere I am not sure what part you are talking about as this is our first experience. Would you recommend taking it off and inspecting if off the trailer rather than trying to pull it out on the trailer? or would it be best to contact carefree and get the info from them?
Old 09-05-2016, 03:39 PM   #11
1973 29' Ambassador
Here is a closer pic.
Old 09-05-2016, 04:50 PM   #12
1976 31' Sovereign
Oswego , Illinois
Smile
The arms that run from belt line up to roller should run strait with seam behind them also the locks that hold arms against side and closed are screwed into this vertical seam. In the pic. I only see lock at rear arm they can not work if arm is angled. The only I can think of is they are at angle instead strait vertical is bottom of arms are bolted into edge of floor [thru rub rail] with lag screws these older AS, the lags tend to not hold because of rot at side or being pulled out. Mine did I glued oversize wood dowel into holes center drilled installed larger dim. lags, first trip out all came loose again. when I returned home pulled awning off, pur. Zip-Dee next day. If they are angled won't hurt if fabric retracks strait. You can google care free for dir. how to install and wind springs. Sorry I gave dir. to person that pur. awning from me Ant Questions you can pm me or email at. bill73r1@gmail.com Bill
Awning Rail Seal? & Awning Wardinbb Awnings 3 08-06-2013 03:37 PM
Replacing awning rod and fabric of original awning ? Mrcrowley Awnings 6 07-10-2012 07:42 PM
Awning or no awning? 2wheelin Awnings 11 04-06-2010 06:38 AM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 08:23 PM
Is the roadside awning option for a 28' Classic really just a single 19' awning? Dave Jenkins Our Community 1 08-17-2003 04:07 PM
