Old 08-12-2017, 08:46 PM   #15
KK4YZ's Avatar
2017 23' Flying Cloud
Hiawassee , Georgia
It seems a lot of this should be caught in PDI...certainly the HDMI cable issue. No excuse for that on airstream or the dealers part.
The Aframe is steel and regularly gets bumped by chains, etc. I think even the manual tells you that taking a wire brush and rustoleum to the A frame is an annual maintenance item.
Our 2017 FC, which we picked up in April, developed a couple of minor issues. Minor but aggravating at the time. The rear hatch lock failed and had to be drilled out to allow me access so we can leave on a planned trip. The dealer sent me a new latch assy and reimbursed me for the locksmith. The Atwood power jack failed. Atwood sent me a new one under warranty.
These were all working at the time of delivery. No way AS or the dealer could have caught that.
What I DO fault AS for is putting Goodyear Marathons on trailers with 10K lbs GVWR with very little margin between tire load rating and GVWR.
I've had stick built box trailers before. The AS is definitely better built than those. Although I do agree for the money, these things should be bulletproof, so to speak.
KK4YZ is offline   Reply With Quote
Old 08-12-2017, 09:39 PM   #16
2007 22' International CCD
No more bulletproof than the average small aircraft. The systems and construction are similar. That said, our only issues have been self induced. Ramp strike wrinkles are "beauty marks". That's my story and I'm sticking to it...
Old 08-13-2017, 07:24 AM   #17
KK4YZ's Avatar
Hiawassee , Georgia
Excuse my ignorance but I gotta ask: What's a 'ramp strike wrinkle'?
Old 08-13-2017, 07:34 AM   #18
DaveMc's Avatar
2005 30' Safari
Montgomery , Texas
Likely just above the belt line as a small crease in the outer shell. Caused by pulling in/out of driveways with steep inclines/abrupt angles.
DaveMc is offline   Reply With Quote
Old 08-13-2017, 08:49 AM   #19
2017 19' International
Tallahassee , Florida
ABC News did a piece on Airstreams the other day ... reported that Airstream's workforce had 153 people in 2008 ... today, well more than 800.
I'm guessing that most of that employment growth was in recent years.
That's a lot of people to train in complex construction methods, and it might have something to do with quality issues.
WhereStream is offline   Reply With Quote
Old 08-13-2017, 10:16 AM   #20
Mollysdad's Avatar
Originally Posted by kendrick.l.j View Post
learn how to do repair on your own. Most issues aren't worth dragging your trailer back to the dealer.
The suits at Thor are well aware of this. They use it to their advantage. I see where Thor's profit is up 40% while you all say quality is down. Coincidence? I doubt it.
Originally Posted by DRPREECE View Post
... The header, wall separation, door leak, and transfer switch were corrected at the factory service center in Jackson Center.
We left the unit there for two weeks for the work to be done. They did a remarkable job. They actually replaced the entire wall and bathroom door. The entry door need adjustment and was missing caulk. The door repair was tested by several heavy rain downpours and not a drop of water came in. Have yet to test the transfer switch.
Yes the quality has issues. However, if you can get it back to JC for the repairs, they do an awesome job in correcting the production issues.
Owners should do this more often, to make the higher up's at Thor realize that warranty repairs eat into their bonuses. As long as owners fix everything, they'll be more for you to fix.
Originally Posted by Passin Thru View Post
To Airstream's credit, they had left plenty of wire coiled up under the coach so I could take the step out where I could work on it without cutting wires.
That's because it cost Airstream $0.50 to pay a worker to cut the wire to the proper length. Too time consuming. Go, go go.
That's probably the length Quickie sent.
Mollysdad is online now   Reply With Quote
Old 08-13-2017, 10:21 AM   #21
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Well said!
Old 08-13-2017, 11:09 AM   #22
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Start to take apart the interior of a Silver Streak and and in hidden places you find . . . dust.
Airstream was always the bargain-brand aluminum trailer.
Innovation stopped when Wally died, and weight became disproportionate about thirty years ago.
Deep pockets saved AS to use as a prestige brand. So, be glad.
As others have mentioned, a punchlist is the procedure for new purchase. After a year or two of normal use, probably won't still be finding factory mistakes.
About a ten year honeymoon should commence if covered storage is used.
Old 08-13-2017, 03:32 PM   #23
A ramp strike, in the airplane business is dragging some part of the airplane on the tarmac during landing or take off. Obviously not a good thing.
I collected a slightly buckled lower rear corner when I dropped a wheel off the edge of a driveway and the skid under the streetside bumper hit the ground.
The only reason I'm not in deep trouble over it is that DW insisted on a hurried departure. (And we all know is in charge from the right hand seat)
Coincidentally, hurried departures are also when airplanes get similar bends....it's fixable, but not leaking, so it's an 'experience mark'
Old 08-13-2017, 03:54 PM   #24
KK4YZ's Avatar
Hiawassee , Georgia
Got it
Old 08-13-2017, 08:53 PM   #25
The weird part is temperature cycling around here seems to be reducing the look of the wrinkle
Old 08-15-2017, 01:04 PM   #26
Tinbox
Tinbox's Avatar
1964 19' Globetrotter
Panama City , Florida
I have a 2014 International Sterling and noticed the floor was soft in the back near the bed. Upon inspection I found there has been a water leak for long enough to rot the wood floor under the floor covering. I have contacted AS about the issue and am waiting for a resolution. I have only had the AS for a little over a year. I am sure the company will do the right thing and I am still an airstream addict.
Tinbox is offline   Reply With Quote
Old 08-15-2017, 02:02 PM   #27
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Let us know if it turns out that way. Evidence on this Forum indicates that AS treats leaks as wear and tear, your problem, unless the trailer was just delivered. For a 2014?
Larry
lsbrodsky is offline   Reply With Quote
Old 08-16-2017, 05:13 AM   #28
Reads a lot
Titusville , Florida
Tin box, I am hoping for your sake that you took delivery directly from a dealer and purchased your 2014 very late, like sometime in 2015 but still new, no previous owner. I would be concerned about the warranty expiration if it were me. As stated earlier AS may view water leaks normal wear and not design flaw or production issues. I am very interested in what AS has to say about an interior water leak 3 possibly 4 years out. Please post. Truly hoping that you will be very happy with their answers.
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
59 vs 67 interior quality JimC General Interior Topics 2 05-19-2003 08:26 PM
Thoughts on quality and prices ipso_facto Our Community 4 04-29-2003 09:04 PM
No comparison in quality! Debbie 2002 - 2005 International 1 01-17-2003 05:23 PM
RV Antifreeze Quality jcanavera Winterizing, Storage, Carports & Covers 8 11-27-2002 04:32 PM
looking for info-questions about airstream quality jclem Our Community 4 10-06-2002 03:28 PM
