Old 12-30-2017, 06:51 AM   #1
Dixon , California
Cool AS 2017 classic
Hi all;
I have a 2017 AS classic. My current issue is the 12vdc system is not functioning. I had this problem about 6 months ago and the converter module was replaced. Also at that time I replaced the Interstate batteries with Duracell maintenance free deep cycle batteries. Checked all circuit breakers and fuses (all OK). Plugged AS to my truck and firefly system functions normally and batteries begin to take a charge. I have a 50amp circuit installed at my home. So shore power good.
I believe there is and a heavier duty converter is available and was installed. How can I tell? I have an extended warranty. Problem is getting it in for repair and we have a South Lake Tahoe snow boarding trip planned next week with grand kids.
Any suggestions?
AndyT
AndyT is offline   Reply With Quote
Old 12-30-2017, 11:57 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Andy.. is the trailer 12volt system in 'store' mode? What is voltage on the batteries? You realize you are required to have a working 12 volt system so that the breakaway system can have power to operate in event of activation..? It is possible the converter has failed. it is also possible the 120volt circuit breaker for the converter has tripped... and it won't charge the batteries... You will need to do a few checks...
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-31-2017, 08:02 AM   #3
2012 19' International
Southeastern MI , Michigan
Aren't the trailer brakes and breakaway system independent of the converter?
Countryboy59 is offline   Reply With Quote
Old 12-31-2017, 10:24 AM   #4
Mollysdad's Avatar
The breakaway switch is wired directly to the batteries.
Old 12-31-2017, 11:19 AM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
sorta. My perspective is a complete system..
- The converter charges batteries.
- Batteries provide power to the Breakaway switch, and, if working properly, battery power (12 volts direct current (VDC)) is available to operate the trailer brakes if the unthinkable should occur.
- the 'Breakaway' switch should be checked REGULARLY that it will engage the trailer brakes properly..
More info needed on the trailer power levels to proceed.
Channing
WBCCI# 30676
Old 01-01-2018, 02:15 PM   #6
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi AndyT,
We're sorry to learn about the issue you are having with your 2017 Classic. Please call our customer service and technical support team at*1 (877) 596-6111, option 2 so we can learn more and help.
Thanks.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
2017 4Runner and 2017 Sport -- Weight Distribution Hitch Recommendation? alberto52 Hitches, Couplers & Balls 2 08-17-2017 09:38 AM
NorCal : 2017 Olema Spring Rally April 7-9, 2017 (formerly at Casini) HootMon-Frau Forum Rallies & Meet Ups 14 04-01-2017 01:46 PM
2017 Classic @ Colonial HeavyAssault 2016 - Current Classic (all lengths) 46 06-22-2016 11:50 AM
2017 Classic Upgrades Packerman Airstream Trailer Forums 2 05-29-2016 11:39 PM
