Old 11-02-2002, 09:39 PM   #1
airstreamcaravel's Avatar
Apron ideas?
Anyone done any creative aprons to give the old trailer that
"Park Model" look?
I figured it would help keep down the moisture, provide a deterent to winter varmints, and also help with insulation.
I had something silvery in mind ... don't think corrgated is quite what i'm looking for ....
Any ideas?
DMC
airstreamcaravel is offline   Reply With Quote
Old 11-03-2002, 06:08 AM   #2
LOST , Hawaii
You could get some aluminum sheet cut to size, but unless you did a lot of work to seal it to the sides and ground I don't think you would stop the critters, they get in some tiny holes. I aslo think you would do better with the airflow under it. Any moisture from the ground, pad where it is parked, etc. would be trapped and freeze inside. The tighter you seal it to stop the critters the harder it will be for moisture to escape.
John
74Argosy24MH is offline   Reply With Quote
Old 11-03-2002, 07:10 AM   #3
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Sealing:
You will also seal any leaking propane fumes creating a confined area ripe for an explosion.
It will not deter moisture, it will actually trap moisture.
It would create a critter haven, out of the elements.
-BobbyW
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 11-03-2002, 12:12 PM   #4
ants & other little critters
FYI-
I've found that the cloth apron touches the ground, which gives ants and other critters another avenue into your trailer(FL is an ant haven). I use wheel covers for UV protection.
John
John is offline   Reply With Quote
Old 11-03-2002, 12:58 PM   #5
General Opinion
So I guess the general opinion is that an apron ... though "smart"
looking on park models .... may not be so smart ....
The negatives seem to outway ANY benefits...
DMC
Old 11-03-2002, 01:19 PM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
how about the "hayseed park model"?
just go get some bales of straw! yee haw!
john
Old 11-03-2002, 01:31 PM   #7
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
don't like that?
or if your lot slopes, how about the "cinder block park model"?
john
Name:	2redneck high rise.jpg
Old 11-03-2002, 02:02 PM   #8
I love it !
Critters can jump that high .... can they?
DMC
Looking for window ideas mcostanzo Upholstery, Blinds, Walls & Interior Finishes 26 10-06-2006 02:17 PM
Classic models - 2002 Classic baldeagle 2001 - 2005 Classic 48 04-16-2004 10:31 PM
Ideas to change the floor plan / interieur of a 1979 Safari Hans General Interior Topics 0 12-23-2002 10:58 AM
Ideas, suggestions, needs? ALANSD Forum Admin, News and Member Account Info 5 06-22-2002 09:21 PM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
