Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 06-28-2003, 10:51 AM   #1
71Overlander
71Overlander's Avatar
Profile:
Ant Problem!
About a week after we got our Overlander home, I started noticing ants (the big black kind) in the kitchen and around the front gaucho. I bought some of the Raid ant traps and set all four up throughout the trailer (which according to the package should have been more than enough). The directions said it could take up to two weeks before they are all gone. It's been 3 weeks and I'm still seeing them - not as many, but one is too many for my liking!
I believe the ants came with the AS. It was parked in the PO's yard under a tree and I noticed a lot of them on and around the tree. The AS is currently parked in our driveway, right beside the house and I do not want them to migrate in the house!
My husband is wanting to set off one of those bug bombs but I think I read somewhere not to do that....was thinking it was here but can't seem to find the thread. Any suggestions??
71Overlander is offline   Reply With Quote
Old 06-28-2003, 11:12 AM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
You might try a different type of ant trap. We had a big ant problem awhile back and got both the white & black ones by Raid. They had different chemicals in each & being that I'm not a chemical engineer, I couldn't decide which to get...so I got both! They worked! Another thought is...the ones you got may have exceed their shelf life...good luck! I HATE ants!
Shari
Old 06-28-2003, 11:33 AM   #3
wingfoot
Profile:
Ants
I am trying one of the commercial preparations right now. Has been one week. It is one of those where the ants take it back to their nest. We'll see.
I currently park the airstream under trees; thought the shade would be better than the summer sun on the finish. The ants appear to come from the trees.
I am pricing covers as we speak.
wingfoot is offline   Reply With Quote
Old 06-28-2003, 03:20 PM   #4
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Hope I'm wrong but big black ants are usualy carpenter ants. Their dinner is wet wood. Might start doing a through inspection for water damaged floors.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 06-28-2003, 03:27 PM   #5
startrekker2001
startrekker2001's Avatar
Profile:  1978 31' Excella 500
Palm Bay , Florida
Images: 34
We have the "sugar" ants. Little red ones and they get into everyting. I use fire ant granules anywhere the trailer touches the ground. Wheels, stabilizers, jack, electrical cord, hose and so on. This seems to work pretty well. The ant's take the granules back to feed the queen. The queen dies and the colony dies too.
Good luck,
Vic
Vic Smith
WBCCI #6782
31' 78 Airstream Excella 500
2001 Ford Excursion V-10
Reese hitch and dual cam sway control
startrekker2001 is offline   Reply With Quote
Old 06-28-2003, 04:15 PM   #6
71Overlander
Profile:
59toaster - My husband fears the same thing. I truly hope that is not the case. We have inspected it pretty thorougly, and havent noticed wet wood but they seem to be coming from under the gaucho. We can't really tell what it's like at the rear of the gaucho.
I am going to try another round of traps as well as the granules. I am hoping they were feasting on the tree beside the AS and just made their way in.
Old 06-28-2003, 05:14 PM   #7
59toaster
59toaster's Avatar
Atlanta , Georgia
Images: 22
If your goucho is like mine it's pretty easy to get it appart where you can see the floor. The water tank may be under it as well. Ours has drawers under it.
Pull the seating off. should be a few screws holding the plywood down. after you get the screws loose the plywood deck should come right up. If there is not enough room to get your fingers in around the ply wood, slide a drawer out and you can push up on the deck from below. Get a screw driver out and start pushing it into the floor and see if you find any soft spots. pay close attentions to the area where it meets the shell. That's the place that usualy get's wet first.
While the belly pan does a great job in preventing water from getting to the wood and insulation from below, if water gets at the wood from above it causes a big problem. The air can't circulate and the water just sits there.
Once the wood dries out the ants will leave. That's why I am concerned that you have some wet flooring.
1959 22' Caravanner
Atlanta, GA
Argosy water fill problem mcneon Argosy Motorhomes 1 10-09-2003 06:30 AM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 01:59 PM
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 18 08-18-2002 10:24 AM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 09:21 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 02:05 PM
