Old 07-12-2004, 06:48 PM   #1
tracker
tracker's Avatar
1969 23' Safari
crescent city , California
airstream unknowns
I have my eye on a 1959 airstream that has undergone extensive remodel. I like what I see but Iam wondering just what I should be looking for.My major concern is the axle and undercarriage on a trailer that old. this would be my first airstream and I would like to know if the other members have any tips on what I should be looking for.
tracker is offline   Reply With Quote
Old 07-12-2004, 06:53 PM   #2
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
what to look for
I would be most concerned about the floor. Axles, although not cheap can be easily changed out. To repair/replace a floor can turn into a serious project depending on the extent of damage. I'd also take a screw driver if possible and probe the frame for soft rust spots. Those 3 areas are the potential deal killers or negotiation points. Good luck!
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 07-12-2004, 06:53 PM   #3
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
tracker???
Didn't you post this same question the other day, or...I must be losing my mind??
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 07-12-2004, 06:59 PM   #4
Images: 59
What model, and how many axles?
If it is a single axle, the running gear may be ok if the interior modifications didn't add appreciable weight. Depends a lot on how well the previous owners maintained the brakes and bearings. I wouldn't tow it without checking the brakes, tires, and bearings.
I have replaced the axle in my '59 Tradewind, but I plan to add a lot of new upgrades, like a graywater tank, A/C, batteries. I believe the original single axle tradewind had an axle rated at 3500#, and the dry weight was 3160#, not much margin for food and clothing.
Let us know more about your potential purchase.
Airstream unknowns tracker 1959-69 Tradewind 13 07-14-2004 01:29 PM
2005/2006 International Rallies Over59 WBCCI Rallies & Events 21 06-24-2004 10:55 AM
Where do you shop for Airstream stuff? cwbastian Commercial Listings 4 05-16-2004 01:30 PM
airstream! airstream! airstream! 83Excella Our Community 0 03-23-2002 10:37 PM
