07-24-2010, 12:20 PM
#21
1972 27' Overlander
Newark
, Ohio
Cantrell,
You are right. Thanks, I should have looked closer. I am having a hard time seeing straight, looking thru the fire in my eyes. at this jerk!
07-24-2010, 12:41 PM
#22
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County
, Ohio
pictures
Put up some clear and recent pictures of your trailer if you have any. We will all keep looking!
Dagnabbit! These trailer thieves are just way too bold!
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
07-24-2010, 01:06 PM
#23
Salem
, Oregon
Originally Posted by jazz1945
I had a Reese hitch pin lock on it, but evidently that is not enough.
Hi, if you mean a lock on the coupler latch, that is not enough. When I just want to pull my trailer forward to work on it, I remove my coupler lock. I don't remove my latch lock because I use my 2" ball hitch and it slips right inside of a locked 2 5/16" coupler. That might be what the thieves did. They don't need to break or cut the latch lock and make any noise.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
07-24-2010, 01:25 PM
#24
Major Bummer. Hope it was insured for theft. Your not reporting from inside your unit are you? Sometimes when it gets to hot by the beach we go out to the driveway and sleep in ours for the air conditioning.
07-24-2010, 04:27 PM
#25
2002 27' Safari
Carmel-by-the-Sea
Have a question? Of the two photos you have posted, the earlier shot shows this person driving through the intersection passing the cross street without your trailer and in the second shot a little over an hour later from the approaching direction through the same intersection is a bit odd. Looks like an older commercial area. due to what I see is concrete curbs with overhead power lines. Nice street light on the corner by the way to aid the security camera. Is this Dayton Road or somewhere else in Newark? If this isn't Dayton Road it maybe a good location to continue reviewing security tapes for this vehicle coming back into this location later.
07-24-2010, 04:28 PM
#26
1972 31' Sovereign
Lexington
Does the trailer have a license plate on it? State and plate number would be helpful.
Chris
07-24-2010, 05:38 PM
#27
2007 25' Safari FB SE
Eureka Springs
, Arkansas
Jack,
You might use this to check Craigslist nationwide:
SearchTempest - The EASY way to search Craigslist
I've found it useful in my searches for tools.
Here's to you getting it back and the creeps getting busted!!
07-24-2010, 10:52 PM
#28
1963 22' Safari
2020 27' Globetrotter
State of
Hoping to slow someone down on ours, we added a "boot" figuring that it in combination with a good hitch lock, and a quality pad lock on the pin would make someone more interested in an easier target...
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
07-25-2010, 12:15 AM
#29
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
A campground owner locally caught people stealing from his storage area, they just hooked the CHAINS up and pulled away, no ball, no lights or brakes - NUTHIN! I'd assume they'd get a few blocks away, then figure out how to get the lock(s) off the hitch, then hitch up properly. Makes me think I should get heavy duty latches and make the chains removeable. Of course a canny thief probably comes with spares!.
Paula
07-25-2010, 12:21 AM
#30
Virginia Beach
, Virginia
Your post made me look at the photos more closely too. There's no Airstream in the first picture (the one on the right hand side). The driver of the truck is just passing through. In the second picture.... There's the Airstream.... Is the driver backing it up to turn it around? Clearly by the lights and surrounding cars the shot is the same. Where was the Airstream stored in relation to these shots?
Paula
07-25-2010, 01:35 AM
#31
2005 19' Safari
GLENDALE
, AZ
I cleaned up this photo a little with Photoshop. Hope someone catches this guy...
07-25-2010, 07:53 AM
#32
1971 23' Safari
Groveport
, Ohio
I will Keep an eye out jack
I cannot imagine him traveling very far with that combination of TV and trailer weight. The back roads are not for the light hearted and going east it gets worse. Good luck
Robert
07-25-2010, 08:10 AM
#33
1965 26' Overlander
Chapin
, South Carolina
Very upsetting, we'll keep our eyes peeled when out and about. You really have me rethinking my security, thank you for posting. Currently I'm just using a master lock on the hitch in the closed position, I know it is not secure at all. I was thinking about going with the reese ball lock but now I'm reconsidering.
How long does it take to put on and off one of those tire locks?
Russ
07-25-2010, 08:48 AM
#34
1977 27' Overlander
Trotwood
, Ohio
With that TV I dont think its very far away.Keep lookin in your area.I hope Im not correct but they probably stole it to strip the aluminum. Check the local Scrap yards. I have a friend thats a repo man and he says a heavy chain thru the wheels is very effective.
I sincerely hope they catch this guy. How come my friend in Newark say's there was nothing in the local paper about this thieft.?
GOOD LUCK
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
07-25-2010, 09:00 AM
#35
1963 22' Safari
State of
Russ, took me about 2 minutes the first time to put that tire lock on, am sure I'll do better the second time. Pop off the hubcap, unlock it, uses a spinner wrench to tighten the claw around, the rim, then crank down the lug nut cover, then lock the cover and you're out of there. It fits really snug, doubles asa great forward wheel chock, and has two spikes that blow the tire if someone really things they are going to pull forward to force it off.
Hope they find that creep for you and get your trailer back.
Scott & Megan
07-25-2010, 09:21 AM
#36
1967 24' Tradewind
Greenville
, South Carolina
Might want to check the local 7-11 type convenience store as it looks like he might have one of the giant "Big Gulp" type drinks. Maybe the store got a better pic on their surveillance.
07-25-2010, 09:49 AM
#37
1965 20' Globetrotter
Fairfield
, Connecticut
Jack, I hope yoy get it back, at least the photos give you something to start with. If your location is less populated that tow vehicle may be identifiable. I had to leave my trailer at an unoccupied home for a couple of weeks when I purchased it from a tag sale. I suspected some of the other bidders were scrappers so I jacked it up and took one wheel with me until trailer was ready to move. I will probably continue to do this at home and elsewhere.
07-25-2010, 10:08 AM
#38
Belington
, West Virginia
Here's a shot of an old GMC Jimmy that I stole from Google Images. I'm pretty sure that's what's in your picture.
07-25-2010, 10:27 AM
#39
1958 26' Overlander
Mesa
Hmmmm, that sounds like a cheap and effective way to secure your trailer. This thread really has me rethinking security. I've got a Gorilla Guard hitch lock, but as pointed out here, a 2" ball makes it totally ineffective.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
07-25-2010, 10:32 AM
#40
2000 25' Excella
Kingston
, Tennessee
we will keep an eye out for it also here in tn, on craigslist, newspapers, and golsn. I really cant stand theifs!
