Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 07-07-2008, 07:17 AM   #1317
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Originally Posted by ROBERTSUNRUS View Post
Hi, just waiting for Andy to spot that picture to let someone know that it needs new axles. Top of the rims at wheel well opening. Really nice looking trailer though.
I mentioned that to the owner's relative and that a better way to determine if the axles were gone was to climb underneath to look at the tension arm. I explained that if the tension arm is in a negative arc then the axles need to be replaced. I also told him to visit Inland Rv's website to determine if they were bad.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-08-2008, 12:59 AM   #1318
ROBERTSUNRUS
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Originally Posted by SARGE/AF View Post
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Robert
How can you tell that it needs new axles? I have a 1976 Soviergn 30FT and it sets like that, when I took it to the factory and had it inspected the only thing that they found was the shocks was bad, further inspection of the axles found the axles themselves in good shape and they are the original. I said that I wanted the bearing pulled and repacked unless they are showing some wear then replaced. They also said that it is not uncommon for a trailer to set that low on the tires, that if it was down to the rim then there is a problem. I looked at the display axle in the front and other than bearings it did not look like there was much could go wrong with the axle except for breaking.
I need to make a trip to the factory to review the repairs being done, and because there are some upgrades I have decided to add too, I plan on talking to them more about this axle thing. I dont want to get it back and then find out there is something wrong. I want it right before I pick it up.
Sarge
Hi, Sarge. If you look at the picture of the trailer we are talking about, you will see that you cannot see any of the tire above the rim and that the rim seems to be in line with the wheel well opening. Weak axles or very overloaded. Now I will post a picture of my Safari and you will see that most all of the tire shows below the wheel well. I don't have a direct side view picture of my trailer, but if you click to enlarge my picture, I think it shows a little bit better.
Name:	My Picture CD 078 (Large).jpg
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 07-08-2008, 08:41 AM   #1319
47WeeWind
47WeeWind's Avatar
Profile:  1948 16' Wee Wind
1964 19' Globetrotter
Denver , Colorado
Images: 13
Wheel well visibility not consistent indicator.
Hi Everyone:
Just a word of caution on using how much tire or wheel rim appears in the wheel well of a vintage Airstream as an indicator of axle condition. Specifically for the 1962 model year (the only year for which I have hard data), the height of the wheel well horizontal top lip from the top of the plywood floor differed by 2 inches between the LA and Ohio factories. The Ohio wheel well cut out was 3 inches above the plywood floor, whereas the California wheel well cut out was 5 inches above the plywood floor. So on brand new 1962 Airstreams, there was a 2 inch difference between trailers made at the two factories in how much of the wheel and tire assembly was visible in the wheel well. That 2 inch difference is a significant portion of overall axle trailer arm travel and will lead to a false prognosis. There likely exists differences in wheel well height between the two factories for other years too, so use caution when employing the wheel well test on older Airstreams.
A much better indicator of axle rubber condition is to stick you head under the trailer and look at the actual angle of the trailing arm to the frame rails.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Charter Associate Member FCU
Airstream Life "Old Aluminum Adventures"
47WeeWind is offline   Reply With Quote
Old 07-08-2008, 09:06 AM   #1320
Newlyweds
Newlyweds's Avatar
Profile:  1975 25' Tradewind
Stoughton , Wisconsin
Northern Wisconsin!
We were traveling south on Hwy 45/47 and passed an older Airstream going north towards Antigo, WI. We were so geeked! They flashed their lights and we waved like crazy! Sorry, it happened so fast didn't get a photo. It was our first trip in our AS, and our first AS sighting while towing ours. Woohoo!
Newlyweds is offline   Reply With Quote
Old 07-09-2008, 08:01 AM   #1321
Aage
Profile:  Currently Looking...
Aurora , Ontario
There's a bank here that's running an ad (I think it's BMO) and the ad is a cartoon of a family. The father has huge long legs, like a daddylonglegs spider has relative to his body, the point being he can travel quickly, carrying the children with him.
(getting to the point soon here.) Well, at one point he steps over a mountain, and as he strides over the valley, at the bottom left of the screen is a perfect little cartoon Airstream (polished and waxed!), which I would guesstimate, has a Bambi's ratio of length vs height.
Old 07-09-2008, 08:25 AM   #1322
Steve & Susan
Steve & Susan's Avatar
Profile:  2005 28' International CCD
Willoughby , Ohio
I was watching teevee last evening to get storm coverage here in the Cleveland area - we got POUNDED!
There was a traffic shot of our "innerbelt bridge" which carries Interstate 90 West and Interstate 71 South traffic together for a few miles.
There was a shorter 2-axle AS being towed South/West bound in a horrible rainstorm - I hope they got to their destination safely!
Steve & Susan
2005 28' CCD, 2002 Silverado-C1500, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 07-09-2008, 10:56 AM   #1323
airedale
Miss Rivette
airedale's Avatar
Profile:  1965 17' Caravel
Hell , Michigan
We were on US 2 east-bound in ND, MN, WI, and MI and we saw about 8 Airstreams.
Laura Miss Rivette 2008
W8JUZ --......--
"Support Search and Rescue, GET LOST!!!!"
Operation "SAVE RUDY" Strike Team (Charter Member)
Check out my Airstream Blog
airedale is offline   Reply With Quote
Old 07-09-2008, 09:21 PM   #1324
GreatPumpkin
GreatPumpkin's Avatar
Profile:  1964 26' Overlander
Colville , Washington
Images: 70
Pulled in to work today and saw an '00 Airstream Excella in my parking lot! The gentleman was walking back to it as I was getting out of my vehicle, so I chatted with him for awhile. He wasn't familiar with the forums, but he highly recommended Airstream Life. I never did get his name, but his trailer had WBCCI # 1898 and 6 stars.
AIR 12256
1964 Overlander
1999 Dodge Ram 1500
2001 Honda XR650R
"In regione caecorum rex est luscus."
GP
GreatPumpkin is offline   Reply With Quote
Old 07-09-2008, 10:14 PM   #1325
cameront120
cameront120's Avatar
Profile:  1972 25' Tradewind
I wonder what the stars mean.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 07-09-2008, 11:46 PM   #1326
airedale
Miss Rivette
airedale's Avatar
Hell , Michigan
I think it mean for every 5 years you have been a member of the WBCCI
W8JUZ --......--
Old 07-10-2008, 08:55 AM   #1327
Mel
Mel's Avatar
Profile:  1967 22' Safari
1960 18' "Footer"
Edmonds , Washington
Saw an Excella being pulled on southbound I-5 through Seattle on the Ship Canal Bridge yesterday afternoon around 3:15. My carpool partner is slowly learning not to jump too high when I scream "Airstream!"
Mel
1960 Caravel "Boris"
1967 Safari "Sparky"
My Photos
Mel is offline   Reply With Quote
Old 07-10-2008, 11:15 AM   #1328
wkerfoot
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
Laura,
You got it right, I picked up a five year star this year at Bozeman. They are free.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
wkerfoot is online now   Reply With Quote
Old 07-10-2008, 11:18 AM   #1329
streamer23
streamer23's Avatar
Profile:  Bridgewater , Nova Scotia,CANADA
Images: 18
My wife used to be the same way too.Now I have to be careful not to jump when she calls out Airstream.
Mike
WBCCI #32083
AIR #7916
Washington DC Unit #170
streamer23 is offline   Reply With Quote
Old 07-10-2008, 05:03 PM   #1330
airedale
Miss Rivette
airedale's Avatar
Hell , Michigan
Originally Posted by wkerfoot View Post
Laura,
Bill
SWEET, just think if Im still kicking when Im 71, I could have 10 stars, wow, thats a lot of BLING!
W8JUZ --......--
