Old 10-02-2017, 02:45 AM   #6819
4riveteers's Avatar
2016 27' Flying Cloud
SF Greater Bay Area , California
And last but certainly not least...Click image for larger version
ID:	296050Click image for larger version
ID:	296051Click image for larger version
ID:	296052Click image for larger version
ID:	296053Click image for larger version
2016 27 Flying Cloud FB
2005 GMC Yukon XL 2500 4x4, Equal-i-zer Hitch, 4.10 axle ratio.
4riveteers is offline   Reply With Quote
Old 10-02-2017, 05:48 AM   #6820
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
On the road. (Interstate 44 near Springfield Mo)
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 10-02-2017, 06:09 AM   #6821
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Attachment 296056
The trailer on the back of the transport looks like a European model with the large triangular reflectors on the rear.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 10-02-2017, 07:05 AM   #6822
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Originally Posted by STREMN View Post
Although not on topic as true AirStream sightings, still this pair has some interesting beauty all on their own. Both were spotted basking in the nice weather we've had over the past week.
I've never seen an Avion before. Amazing how similar but different from the AirStream line. The Fifth wheel with the customized Peterbilt TV, well...just a conversation starter for sure.
Tom - S/OS #025
Nice photos. I have a neighbor that is a retired long haul big rig driver. A couple of years ago he bought a purpose built PB for towing his 5er.
MICHAEL
Old 10-02-2017, 07:08 AM   #6823
AWCHIEF's Avatar
Images: 33
Also it does not have side or rear windows other than the door. Possibly a purpose built food cart?
MICHAEL
Old 10-02-2017, 07:21 AM   #6824
I think the European models are finished in the UK, with the addition of interiors. Perhaps they have different windows too, although it could just be a protective film on the windows. I also noticed that it has backup lights.
Ray B.
Old 10-02-2017, 09:11 AM   #6825
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Several years ago in the UK, I saw that the interiors that were installed in the UK were so well crafted with "QUALITY" components it made the USA versions look like amateur hour installers had put in the rejects of a bottom tier supplier.
Old 10-03-2017, 04:32 AM   #6826
GettinAway's Avatar
I think the rear added lights were for the actual trailer hauling all three. Otherwise there were no running/working lights going down the road. I did notice no rear window. It was a pretty short unit. Shorter than our old 19' Bambi. I'm not familiar with those shorter ones, not sure if they have a rear window or not.
2011 FC 23FB
Old 10-03-2017, 10:33 AM   #6827
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
No side windows, either.
May be a shell for a custom trailer- food service, retail-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-03-2017, 06:57 PM   #6828
AirstreamJim's Avatar
2007 25' Safari FB SE
Baldwin Harbor , New York
It's definitely a European unit. In addition to the European triangular reflectors, it has yellow turn signal lamps, which is required in Europe.
WBCCI 1433
Long Island, NY
Silver Meteor - 2007 Airstream Safari SE LS 25FB
2016 RAM 2500 Laramie Crew Cab 4x4, Cummins TurboDiesel
AirstreamJim is offline   Reply With Quote
Old 10-04-2017, 02:14 AM   #6829
4riveteers's Avatar
Check it out. U.K. Airstreamer, Andrew Ditton, introduces Airstream U.K.'s 2018 International "Missouri". Shows off European design features including the exterior rear lights configuration.
https://youtu.be/Rloh5H3Ggq4
Old 10-04-2017, 02:21 AM   #6830
Long Island , New York
Originally Posted by 4riveteers View Post
Saw these vintage ladies with fascinating stories at the Vintage Trailer Fest in California's gold country in the town of Plymouth. Started out with an AS barbecue owned by Artistic Airstreams from Concord, Ca in front of an AS they renovated.
Thanks for the many recent photographs, taken personally by you, of actual Airstream Sightings. It is great to see so many AS and vintage kin, so thanks for taking the time and effort to take the photos and to post them here. Your efforts are much appreciated.
Text reports of actual AS sightings are also interesting for the geographic diversity they show IMO.
Old 10-06-2017, 04:01 AM   #6831
4riveteers's Avatar
Why thank you kindly. We're so privileged to be part of the Airstream heritage. What better way to soak in part of that heritage than to highlight it. I always say, if sighting an Airstream makes your head turn, it's definitely eye candy!
Happy travels!
Old 10-06-2017, 09:26 AM   #6832
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Saw five Airstreams heading east on I-10 in the sixty miles between Deming and Lordsburg, NM Thursday afternoon, I am guessing they were headed to the Albuquerque balloon festival.
random sightings
NEW: 5th Wheel Airstream Airtrekker Boondocking 38 06-25-2016 09:52 PM
Considering a used Airstream purchase kmb1966 Buyer Guidelines 11 08-30-2011 05:09 AM
Airstream Trailer, Vintage Airstream, Airstream eBay Watch Airstreams on eBay 0 02-10-2011 08:10 PM
Airstream gimlet AirRowan Classic Motorhomes 4 02-02-2011 10:54 PM
