Old 10-28-2014, 09:10 AM   #4887
Jimbcole's Avatar
1958 17' Pacer
Tryon , North Carolina
Originally Posted by m.hony View Post
Looks like it is set up to double tow- against the advice of 99.99% of owners-
The caster wheels I assume are to prevent bottoming out-
I thought the same thing. I hope this owner is a Forum member. I'd like to know if they double tow.
I've read some discussions on using casters if the angle of departure is too much, to prevent bottoming out. But that is a short trailer. He must have a driveway like mine.
I even refrain from carrying bicycles on my back bumper, even though the spare tire was sometimes mounted on the back of the vintage trailers of the 50's & 60's.
Should I not worry about that and put a bike rack on the back?
Jimbcole is offline   Reply With Quote
Old 10-28-2014, 10:00 AM   #4888
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
There is a bike rack you can buy now that mainly weight is on the frame and it seems good
I read on this forum that those wheels are a terrible idea - I backed into a spot at Vogel state park this year and just barely cleared without rubbing the rear - if I had wheels it would have pushed up on the airstream and who knows what that would do - consensus is argent on this forum is that you are better to risk dragging than to effectively lower your clearance - but I have no idea honestly - I for now will not do the wheels given my own personal experience
Tandem seems like an overall bad ideal
PharmGeek is offline   Reply With Quote
Old 10-28-2014, 02:30 PM   #4889
TCwheels's Avatar
2011 20' Flying Cloud
Traverse City , Michigan
Meanwhile, back at Airstream sightings....
WBCCI #7246
"Don't let perfect be the enemy of better."
TCwheels is offline   Reply With Quote
Old 10-28-2014, 03:38 PM   #4890
Goal15's Avatar
Dallas , Texas
WBCCI #7246
I once "saw" an AS pull into Bull Shoals State Park that had a 12 foot aluminum johnboat trailering off the back of the AS. I asked the guy about it and he looked at me like I was some kind of idiot for suggesting that towing on the bumper of AS might not be a great idea......
now, back to ACTUAL sightings....
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 10-28-2014, 05:32 PM   #4891
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Have been pulling doubles since the seventy's , from tractor trailers to travel trailers with whatever type of trailer that meets the need at the time , including many times in the mountains of Colorado , Wyoming , Utah etc. even on ice and snow in the winter. If done correctly , there is absolutely no problem whatsoever with it . With a little practice , one can back double trailers when the need arises . I certainly have a trailer hitch receiver on our present Safari and a couple of trailers that would tag right along behind it should the need arise .
Regards
dannydimitt is offline   Reply With Quote
Old 10-28-2014, 05:48 PM   #4892
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
That ain't the point-
The frame is not strong enough and any weight/pressure back there will cause rear end or floor to shell separation.
The from doesn't really hold the shell up. The monocoque shell/fuselage holds the frame up-
Other travel trailers or fifth wheels- no problem- the frame is the strongest part of those types of trailers.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-28-2014, 07:25 PM   #4893
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
The frame under the 2005 was as strong as a wet noodle and would not even hold the AS up much less anything else , That's why I rebuilt it . Is no longer a P.O.S.
Old 10-28-2014, 07:56 PM   #4894
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
For pics of this project , go to
Frame Failure - 22 foot International ( 1 2 3 4 5 ... Last Page)
DON GUBRUD
08-23-2013 07:30 PM
by flyrc
and look for posts 242 thru 253 .
Old 10-29-2014, 04:34 PM   #4895
SARGE/AF's Avatar
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
Greeneville , Tennessee
One thing that most do not know on here and it is not talked about is that Airstream is owned by Thor industries, AS does not have a CEO, it has heads of dept, all of them work at Thor. Since Thor has purchased AS they have cheapened the product to make Thor product line better and is one of the reasons motor coaches are no longer produced by AS. I have watched AS go down hill like the rest of you and I often wonder how long before Thor makes AS so terrible that no one will ever buy one and thus closing AS out forever. Thor knows that AS has a following, and they know of this site and wish that it would disappear because of the knowledge on here and that came direct from Thor in one of my heated discussions over AS. I wish that I was in a position financially and of little younger age, I would re-open Avion or silver streak and reproduce the quality of product that old Wally envisioned with updated materials. I am currently on my 3 rd AS ownership and as much as I love my AS especially the Legend that I currently have, I am getting at the point of going to an SOB and most likely it will be a MH, but not a thor junk.
Sarge USAF
WBCCI- none
Good Sam Life Mem
NRA, DAV, PGR, DRA
SARGE/AF is offline   Reply With Quote
Old 10-29-2014, 05:14 PM   #4896
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Rivet
That is 100 % correct Sarge . Whenever someone comes up to us on the road or at a campsite and start drooling about what a great looking trailer we have , I suggest they look underneath at all the work that it took to get it to the point that it was useable , and point to the Thor sticker by the door and firmly suggest that if an Airstream has this sticker on it , do not walk , but run away from it as fast as you can . Old Wally is spinning in his grave .
Old 10-29-2014, 08:42 PM   #4897
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Western WA , Washington
First thing I did was peel off the Thor sticker. That improved the resale value, right?
Rocinante is our 2014 International Signature 27FB
Old 10-29-2014, 09:15 PM   #4898
2008 25' Safari FB SE
Frederick , Maryland
Hijack!
VWill is offline   Reply With Quote
Old 10-29-2014, 09:17 PM   #4899
Goal15's Avatar
Dallas , Texas
Anybody SEE an AS today?
Dana and Olga
2006 Safari 23
Old 10-29-2014, 11:38 PM   #4900
HIGHLAND VILLAGE , Texas
I saw THREE last weekend at a little camp ground in Highland Village Texas. Two older 30+' rigs and a newer Bambi, only spoke to one owner.
Dan in Dallas...
hostage46 is offline   Reply With Quote
random sightings
NEW: 5th Wheel Airstream Airtrekker Boondocking 38 06-25-2016 10:52 PM
Considering a used Airstream purchase kmb1966 Buyer Guidelines 11 08-30-2011 06:09 AM
Airstream Trailer, Vintage Airstream, Airstream eBay Watch Airstreams on eBay 0 02-10-2011 09:10 PM
Airstream gimlet AirRowan Classic Motorhomes 4 02-02-2011 11:54 PM
