Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 06-18-2012, 01:59 PM   #3101
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Thanks, Mike, but that link is blocked by the firewall where I am now. I will check it out when I get home tonight.
MICHAEL
Old 06-18-2012, 02:09 PM   #3102
Mike91208's Avatar
2009 27' FB International
LA LA Land... , California
Here's the description:
This Custom Built Motorhome is for someone who appreciates a unique and finely crafted motorhome with no equals on the planet. Not for someone looking for a cheap bargain priced run of the mill motorhome , yes the price is correct and I realize this most likely will not sell.
I spent 2 1/2 years building this, approximately 6000 hours, using the finest materials available. I wanted an aerodynamic motorhome and to that end I did the following.
1. Used a new airstream 19' trailer which in itself is the most aerodynamic RV on the market.
2. I removed the AC from the top and custom designed the ac unit that fit underneath just behind the rear axle with the intake and outflow vents on the floor with the use of custom built teak vents.
3. Custom built fender skirts held on with 1/4 turn aircraft cowling fasteners in case of tire change.
4. The underneath portion of the motorhome section is completely incased in aircraft aluminum for wind flow except the drive shaft is exposed, with a slight angle rising in the rear section for less drag.
5. aluminum to connect the trailer with the cab for a smooth airflow. There is a 2nd inner panel and steel reinforcement and insulation in this area.
6. The steps are enclosed behind custom fabricated doors that are closed during travel. Even the ends of the original bumper are filled with foam and sealed with aluminum to reduce drag.
All of this has resulted in a smooth, quiet driving RV which gets between 17 and 20 MPG and you can cruise at 80. I also opted for the 3.72 rear end ration to increase efficiency yet it has plenty of power
The entire inside except for the refrigerator cabinet was gutted and redesigned to allow for a queen size bed across the back, therefore the bathroom was reduced in size as for me a larger bed was more important than a large bathroom.
1. a row of drawers was added in the kitchen, a round sink with more counter space, a high end marine faucet is used with a more classic style countertop material.
2. linoleum was removed and solid maple flooring was installed., all the tacky carpet on the walls and ceiling was removed, prepped, and painted a pale yellow.
3. all the cabinet doors were removed and new doors custom made in my shop.
4. The small back window was removed along with the small outer back access door and a full size door and windows installed that come on the 16' Bambi.
A wicker sofa is in the living area with a removable table and a custom removable section to transfer between the cab and the back. I also installed a Xantrex 2400 inverter/charger and 2 6 volt top of the line golf cart batteries.
5. A quality filter system in installed along with a water accumulator. A second water tank was installed to increase capacity to 36 gallons. Also An electric sewer valve in also added.
6.3" rigid board insulation was added within the frame of the chassis for added insulation and quietness.
7. The tow system is rated for 7000 pounds for this vehicle
The Mercedes Sprinter Diesel CabChasis, only has 21000 miles and drives as smooth as a Lexus.
8. All the lower baggage compartments were custom fabricated. One compartment on the drivers side is large enough for a 6' 3" adult to lie in. There is also a pass threw compartment in the back. There is a lot of storage as I wasted no available space.
This unit weights 8900 pounds with full tanks which gives you over 2000 pounds of carrying capacity. I also added electric leveling jacks.
to see more photos see my photobucket by emailing me and I will send you the link I will need an email address Some show before, during and after. Also 1 is me showing this to the top 3 Airstream Executives, they were impressed!
Please call me at 805 682 1075 if you have further questions
Mike91208 is offline   Reply With Quote
Old 06-18-2012, 02:49 PM   #3103
Florida 55's Avatar
2008 27' Safari FB SE
Pfafftown , North Carolina
Images: 42
Airstreams in the Neighborhood
Here are two vintage Airstreams within a couple miles of my home in rural NC.
ID:	161305   Click image for larger version
Chuck
Airstream - 2008 Safari 27FB SE (Sweet Pea)
TV - 2022 Ford F350 King Ranch, 6.7 Diesel, 4X4 (Big Red)
WBCCI 3823 - Unit 12 | AIR 48265
Florida 55 is offline   Reply With Quote
Old 06-18-2012, 03:01 PM   #3104
AWCHIEF's Avatar
Images: 33
"yes the price is correct and I realize this most likely will not sell."
At least he does not seem to live totally in a fantasy world. Price aside it is still an interesting concept.
MICHAEL
Old 06-18-2012, 03:08 PM   #3105
DKB_SATX's Avatar
Alamo Heights , Texas
It's a fantasy to even bother listing it on eBAY on the off chance that someone with $574,999.98 more money than brains would pay that for it. I think he has it listed for some other reasons.. maybe to justify some insane amount on insurance coverage? Reason to think no one "gets it" because they're not lining up to buy?
(and re: the number above... Yeah, I realize it's real value is way more than 2 cents, and if he had priced even in the realm of the very expensive new Interstates I'd think it was at least sane, if ambitious, but at $575k it's just some sort of mental exercise (or defect) I don't understand.)
— David
Old 06-18-2012, 03:16 PM   #3106
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 61
I would think he can put any price he wants to on it. It is no more insane than some of the units that are priced/advertised on the Air Classifieds.
It is only the price catagory that draws attention to this item. And , unless you want to build one, it is one of a kind.
Dave
Old 06-18-2012, 08:12 PM   #3107
Florida 55's Avatar
Images: 42
This Class C Airstream concept of a Sprinter based motorhome seems like it would be successful in today's high fuel cost environment. An Sprinter Class C with a classic Airstream aluminum exterior behind the cab and floor plans like the 2013 Winnebago View or Itasca Navion IQ would be very tempting if I were in the market: Winnebago Motor Homes - 2013 View & View Profile
Chuck
Old 06-18-2012, 09:07 PM   #3108
riverone's Avatar
2012 22' FB Sport
Arkadelphia , Arkansas
Originally Posted by Goal15
Wow! Now i have a picture of the Tundra and Thumper traveling down the road.
We were on our way home after a great week of Airstreaming in beautiful Arkansas.
Thanks so much, riverone.
Dana and Olga
You are so very welcome! We are glad you enjoyed your time in AR. Check out Lake DeGrey your next time through! It is near Arkadelphia, our hometown.
We enjoy traveling to northern AR . Gotta love those hills! I think I hear them calling my name!
Jimmy & Cindy
riverone is offline   Reply With Quote
Old 06-18-2012, 09:20 PM   #3109
Goal15's Avatar
Holly Lake Ranch , Texas
Jimmy & Cindy
Jimmy & Cindy:
We saw Lake DeGrey on the way up when we took 7 up to Hot Springs. Looks like a beautiful lake. We spent a couple of nights at Bull Shoals - White River State Park.... a beautiful park and the weather couldn't have been better... very seldom get to camp in the summer in Texas without the AC at night.
We actually stopped in Arkadelphia the day you shot the picture to grab a burger at the Golden Arches.
Dana
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 06-18-2012, 09:23 PM   #3110
soldiermedic's Avatar
Florissant , USA
Originally Posted by Mike91208 View Post
Saw this configuration at the festival. Owner said he put it together himself.
This was the one recently on ebay for a buy it now of over $500,000 wasn't it?
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 06-19-2012, 07:31 AM   #3111
SARGE/AF's Avatar
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
Greeneville , Tennessee
Did he offer to sell it to you for the low-low price of only half a million dollars?
Sprinter - Airstream halfbreed
We're had some harsh words for it over here.
Maybe thats what I should do to my Norman Rockwell Edition, turn it into a motor home. Even with a Ford F650/750 it would still be under the 50 foot length.
Sarge USAF
WBCCI- none
Good Sam Life Mem
NRA, DAV, PGR, DRA
SARGE/AF is offline   Reply With Quote
Old 06-21-2012, 08:07 AM   #3112
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Self Portrait Super Trouper near Mt. Shasta
Self Portrait near Mt. Shasta-
SuperTrouper is offline   Reply With Quote
Old 06-21-2012, 05:33 PM   #3113
EricktheSOB's Avatar
Flora Vista , New Mexico
About 20 minutes ago on New Mexico 516 between farmington and aztec, there was a blinding flash, and before i knew it a beautiful polished vintage 25 footer being towed by a black Toyota went past. DROOL. My F150 tells me its 105 degrees here right now..wonder if the polish helps keep a vintage unit cooler... lol
EricktheSOB is offline   Reply With Quote
Old 06-30-2012, 08:35 PM   #3114
Whale of a Caddy pulling a single axle AS on route 1 in bodega bay CA. About 6:30 pm 6/30.
Looking for adventure in whatever comes our way.
- Brad
Old 06-30-2012, 08:42 PM   #3115
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
On the road to Sweet Home, OR last week
Name:	Roslyn Mossyrock K&d Sweet Home 2012 040.JPG
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 07-01-2012, 09:13 PM   #3116
Not your average Tiki
Tikiman's Avatar
1968 26' Overlander
Columbia , Missouri
Safari parked this morning at the McDonald's in Houston, Mo. TV had Illinois plates.
Tikiman is offline   Reply With Quote
Old 07-02-2012, 01:32 PM   #3117
2008 22' Sport
Green Mountains , Vermont
Perry's unit.
nesvt is offline   Reply With Quote
Old 07-02-2012, 02:28 PM   #3118
Goal15's Avatar
Olga says she saw a vintage AS pulled by a grey SUV turning off Texas 66 in Rowlett onto the Eastern Extension of the President George Bush Turnpike about 2:45. Always nice to see a fellow AS'er in town, or just passing through. If that was you, say hi!
Dana and Olga
2006 Safari 23
Old 07-02-2012, 08:30 PM   #3119
Sunday on US 550, one newer unit looking like it was doing the national park routine heading south, a classic MOHO (short one) with brown accents heading north, and on NM516 one that needs a lesson: a NEW AS, looked to be 25 footer or so, pulled by a Toyota Tundra with a camper shell. IF it was a nissan i could have called it a TITANic.. it was down by the stern and the whole unit looked like it had a broken back. I was able to see that it had a weight distribution hitch on, but it was so overloaded im surprised the hitch wasnt dragging the pavement. The back of the truck looked full and i bet the trailer was packed full. From the looks of things Id guess the Titanic itself had a tighter turning radius vs length...the front wheels were only on the ground out of habit.
At least it wasnt the Ford Ranger in Durango pulling a 30+ foot toy hauler...
Id get pictures but im always driving... the MOHO was a nice looking unit. havent seen one like that for a while. No numbers on any that I saw, but didnt really get a good look at the stern of the MOHO.
Im seeing a lot of vintage units parked in back yards and being used for housing... I guess since i caught the aluminum fever i see them....
Old 07-02-2012, 09:25 PM   #3120
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
My son emailed me this photo this morning from Smokey Joe's at the Munich airport.
The NSA -- The only part of the government that listens.
newroswell is offline   Reply With Quote
random sightings
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
NEW: 5th Wheel Airstream Airtrekker Boondocking 43 05-30-2020 09:11 AM
Considering a used Airstream purchase kmb1966 Buyer Guidelines 11 08-30-2011 05:09 AM
Airstream Trailer, Vintage Airstream, Airstream eBay Watch Airstreams on eBay 0 02-10-2011 08:10 PM
Airstream gimlet AirRowan Classic Motorhomes 4 02-02-2011 10:54 PM
