Old 12-10-2002, 09:20 PM   #1
xtrm69's Avatar
Send a message via ICQ to xtrm69 Send a message via Yahoo to xtrm69
Cool Airstream Restoration
Hello All:
Im in a postion to be able to purchase a fairly long airstream trailer. It has been gutted out and the shell looks to be in good condition.
Has anyone seen a airstream restored with a all wood interior?? Also where would I be able to find some of the paneling for the walls at.
The floor seems to be in fair condition, possibly a new door gasket and new heater and appliances. There are some good possibilties for this project.
Nice to meet you all.
Darrell
xtrm69 is offline   Reply With Quote
Old 12-10-2002, 09:32 PM   #2
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Restoration
Welcome to the forum.
The nice thing about an A/S is that the "furniture", meaning all the interior walls and everything else inside, is independent of the shell. That means that you can design and build whatever will fit. Probably the only real limitation is the location of ribs to suspend upper cabinets.
There have been several threads on this forum pertaining to wood interiors, some with photos. I suggest you use the search option to locate these threads.
One suggestion was to use wood on the linear portions and use overhead cabinets at the ends where it would be difficult to panel.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 12-10-2002, 11:46 PM   #3
hex
hex's Avatar
Exclamation Big job..big possibilities...big rewards...Big State !
Yes I agree about lots of possibilities. You say long so I assume you are talking about a 27 to 31 ft. model. Do you have any idea what year and floor plan it is/was? Where is/was the toilet?
Are the two or three holding tanks still aboard?
You ask about interior walls. Is the inner skin still there at all?
Is it metal or wood? Has the wiring been removed?
Lots of considerations. I always think of prices in Alaska being higher that most states, but depending on answers to what I asked I have to guess a value somewhere between 500 and 2000 dollars for the shell,continental UsA.
Tires 100 each, axles 1000 each, HotWaterHeater 400, Furnace 500??, refer 300-1800, just a few ballpark figures.Air Cond. Not needed
Cabinetmaking skills would be a real asset. Patience an even greater one. Electrical skill also necessary or contractable.Sheet metal experience a real plum!
Lastly any interior builds need strength at minimum weight, with just a bit of flexibility built in or at least expected after a few 100 miles. And remember that the upper walls & cabinets have that curved line so plumb is a whole new 'dimension'.
Now if its to become a parker-only plans could be a bit different.
There are surely some amazing success stories I have seen on the web. No reason yours can't be another. Good Luck and don't be afraid to ask anything, and don't get discouraged if there is no immediate answer.
Oh yeah and don't fail to take pictures.
hex is offline   Reply With Quote
Old 12-11-2002, 05:54 AM   #4
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Wood interior
Check this interior.
Lots of wood.
http://www.marinestove.com/airstream.htm
Smily
smily is offline   Reply With Quote
Old 12-11-2002, 06:06 AM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Thanks for that link, sure is an interesting interior, and well executed.
Airstream Restoration Service LoydE Commercial Listings 1 04-24-2003 02:28 PM
new to the restoration from Berlin Germany Hagen 1959 Traveler 1 01-09-2003 12:22 PM
airstream! airstream! airstream! 83Excella Our Community 0 03-23-2002 10:37 PM
