Old 04-07-2012, 08:09 PM   #1
Fly at Night's Avatar
2010 27' FB Flying Cloud
Fraser Valley , British Columbia
Airstream - How Can You Get Some Things so Right....and Other Things so.....
....WRONG???
Well, today I decided to open the storage bin under the dinette bench. I think this was the second time I have opened it since purchase. When I went to close it, it would not latch. Seems those cheap plastic black things have gone kaput already. So now it's hanging open like an outhouse door after a Saturday-night brew 'n bustup. Anyone else with the same problem?
Upon closer inspection, the finishing on the far end of that door lip isn't exactly spectacular, is it?
Besides that, the first time I lifted my mattress up to access the under-bed storage compartment, the struts holding the mattress up wouldn't release. No bloomin' way. So, had to take them off to get the mattress back down.
No great tragedy in the scope of things....but annoying just the same. Another little thing that has to be attended to when the unit goes in for dewinterization - while it's still under warranty.
All-in-all I am pleased with my trailer, but I wish Airstream wouldn't cheap-out those things that are "outta sight" because these glitches do not keep them "outta mind."
Fly at Night is offline   Reply With Quote
Old 04-07-2012, 08:47 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, those cabinet latches aren't really that bad, but they can come loose. They need to be adjusted properly and then they work great. If you look at the plastic part located on the door, it is probably loose. See if you can push it up and down. The slots for the screws are for adjustment. Usually you can see the impressions left by the screws, when in their correct position. This will make the adjustment easier. Also look at the part of the latch mounted on the divider, They, also can come loose, but rarely.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-07-2012, 09:09 PM   #3
Hi Robert; those screws on both components are tighter than a what not. No give up and down at all.
Blinkin' thing won't stay shut unless I stick something in to hold it to the frame.
Old 04-07-2012, 09:23 PM   #4
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
FAN,
We have had some problems with those latches also. One of them would slip into its "closed" position while the under bench cabinet door was open. I tried a number of ways to get it back into "open" position. The best tool turned out to be the cork screw on our wine opener. I just sort of "screw" it in and pull the latch open. Give it a try and see if it works for you.
We had a similar problem with the gas piston struts on our bed. I called the PO to see what the "trick" was to close it without breaking anything, he said just put your weight into it and it would close without a problem. He was correct, it closed just fine, but it still makes me nervious each time we access the underbed storage that way so we mostly use the access openings on each side of the bed and at the foot of the bed. Hope these suggestions work for you on your rig.
Good luck,
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 04-07-2012, 09:51 PM   #5
Hi Scott. I took them off. (struts) I don't think I'll put them back on. Will probably put a good ol' cut-off broom handle under the bed to use as a prop up for those occasional times I need to raise the mattress. Or else I'll just access from the side like you do.
I know what you mean by that "nervous" thing. Cripes...I don't want to take any more "nervous" along for the ride.
Old 04-07-2012, 11:22 PM   #6
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Same problem in our 2011 International Serenity. One of the black catches went in to the permanently closed position and even though I could coax it back to open with a screwdriver, it would get stuck again pretty quickly. I just happened to be passing the dealer's place so called in; they gave me a couple of spares, free and for nothing as the trailer is under warranty, and I swapped the bad one out. It is annoying that Airstream uses such cheap components but at least the issue is minor and easily resolved.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 04-08-2012, 05:55 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
We had to have AS send us six of the infamous black latches, all broke within 4 trips. Careful alignment when re-installing solved the problem, (along with a bit of dielectric grease), just another case of.....well never mind, lets just say they had a bad day.
FWIW....Used some velcro while waiting for the parts.
but Im the Husband, so we went to Cleveland. 😘
RLC
Its a crooked piece of time that we live in.
John Prine
Old 04-08-2012, 06:20 AM   #8
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
Velcro is amazing stuff! I used it to secure some of the switch boxes that Airstream elected to leave floating in the stereo installation. Funny how annoying a sound a hard plastic box makes when it is sitting on a speaker...... bad day???
I like the process of "adjusting" the fit of things on our trailer and on our boat too. I believe that no one will be as fussy as I am and that when I am finished things will be the best! In this world of computer controlled everything a simple adjustment brings me much joy..... Sigh.
Bruce
Barely getting by, towing our 16' Bambi with our Ram 2500 CTD "Moby"!
Bruce B is offline   Reply With Quote
Old 04-08-2012, 06:45 AM   #9
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Wow... I had to replace one or two of those in the 18-year-old B190 and I think the trailer has perhaps one that's bad that I haven't bothered to swap yet...but otherwise they've been fine for me.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 04-08-2012, 06:50 AM   #10
sandlapper's Avatar
1993 34' Excella
York , South Carolina
It helps to be handy
.....if you own one of these things, or any type of travel trailer. It is not quite as bad with Airstreams but manufacturers generally sling them together, then expect their dealers to straighten them out. And no one is going to take the time to fix things like you would yourself. Talking here about those little annoying things like catches, hinges, straps, knobs, drawer slides,etc, etc.
They are best fixed yourself, with common sense and a little TLC. The more you can do the better off you will be.
Safe and happy travels.
John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 04-08-2012, 07:06 AM   #11
Thumbs up
"Velcro is amazing stuff! I used it to secure some of the switch boxes that Airstream elected to leave floating in the stereo installation."
It's still holding one of our speakers, replacing three "air screws" and one wood screw. No good vibrations now.
RLC
John Prine
Old 04-08-2012, 08:37 AM   #12
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
All of my black latches either failed, or have needed constant attention since the first year of ownership. I have some metal latches that are used on boats that I'll eventually use to replace the originals. I've learned to accept these minor imperfections and inferior components as part of the modern Airstream experience. American icon on the outside, SOB on the inside.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 04-08-2012, 10:10 AM   #13
I was thinking of using these, with the NSC82 add-on for the under bed doors if the plastic ones broke again, they haven't so I haven't.
RLC
John Prine
Old 04-08-2012, 11:10 AM   #14
MrUKToad's Avatar
Chatham , Ontario
Annoying though it is, I shall look to replace these latches with something more robust if we get any more failures. There are plenty of inexpensive alternatives on the market.
Sewer question - 1968 Airstream goswick Plumbing - Systems & Fixtures 8 04-11-2012 08:37 PM
so why... mack-in-nc Airstream Trailer Forums 14 04-09-2012 10:16 AM
Airstream Overlander 26' ready to customize or restore. No Reserve Auction!!! eBay Watch Airstreams on eBay 0 04-07-2012 07:40 PM
1975 Airstream International Land Yacht eBay Watch Airstreams on eBay 0 04-07-2012 06:30 PM
2006 Airstream 28' International CCD - Excellent Condition - MUST SELL eBay Watch Airstreams on eBay 0 04-07-2012 03:30 PM
