Hey everybody! I saw the VAP doing this and thought it would be a great idea for AirstreamForums.com members to put ourselves on the map!
It's free, just click on the link in my signature then click on "Add Yourself" to the right of the map and show us where you are! You can use just your screen name if you wish to maintain your privacy.
If someone has already started one of these that I don't know about then pm me the link. Enjoy!
P.S. - I've also added a link to the links section. Keyword "Map"
It would be quite convenient to also have a separate map of volunteer inspectors, or maybe just to code that into the existing map with "V.I" in the individual comments, don't you think?
I have been working on this for some time. I will install the first version before the end of the year. It will require a member to place their 'pin' on the map and mark their location. A future version will use the zipcode (or city/state/country) from your profile to automatically map everyone. It's going to be really cool...
Great idea!!! I'm on the map. Although when I zoom in, it shows I'm a mile or so north of my actual address. Guess folks won't be showing up at my doorstep.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
__________________ http://www.airztream.com
It puts your pin near the center of the zip code you enter. I think if someone were to pay for a "premium" type map, more options would be available. I just set up a free one.
'74 Overlander (Rear Bed)
'77 20' Argosy MH (Looking for a new home)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281 w) www.balrgn.com www.balrgn.com/Airstream.htm
Ben,
I might need a little help. I am trying to add my address (Richmond, VA) For some reason I do not show up on the map. I do show up as a member (vajeep) Will the map let more than one member per city??
Thanks!!
Abe
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
WBCCI# 7627 / VAC
Air #2798
Ben,
Thanks!!
Abe
You're on there right behind Troubleskeep. If you click on your name on the right, it will pop up your pic and bubble.
