Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 11-08-2012, 06:35 PM   #1
1996 34' Excella
Atlanta , Georgia
airstream 31--
HOW CAN I EDIT MY AD??? maxline@mindspring.com
Wayne Gayre is offline   Reply With Quote
Old 11-08-2012, 07:37 PM   #2
SteveH's Avatar
Common Sense , Texas
PM a moderator.
Old 11-08-2012, 08:45 PM   #3
Ottawa , ON
Here's something I put together for editing an ad:
To edit your ad:
Go to your ad, and first make sure you are logged in. To confirm you are, look to the top dark blue horizontal line. At the far right side it should say "Logout". If it says Log in, click on it and do so.
Then enter your ad. In your ad, the second from the top horizontal dark blue line has "Product Options" just to the right of the middle. Click on it, then click on "Edit Ad". Once you do that, you will see the same screen you used to enter your ad the first time.
Make any changes you would like to, then at the bottom of your ad, find the white box to the left of the box with "Submit" in it, and click on the box to put a check mark in it.
Then click on "Submit", and you are finished.
Or:
To delete an ad, under Product Options, just select Edit/Delete, then go down to the bottom, and click “Submit”.
Ps: my screen may be slightly different than yours because I am a moderator. Look for similar names, if the labels on choices aren’t exactly what I said they will be.
If anything is not clear, or if your menus are different, let me know and we will work it out.
On behalf of
The Site Team
