Old 05-16-2015, 08:15 AM   #1
Old Lyme , Connecticut
Air Compressors
We have been enjoying our 2014 Flying Cloud 27FB and was wondering if anybody out there takes along an air compressor? If so, do you have any advise on type, size, brand, etc? I do not plan on running any tools just looking for a handy way to maintain proper air pressure in the trailer and TV tires.
Thank you
kdz03w is offline   Reply With Quote
Old 05-16-2015, 08:24 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Welcome,
Several treads on the subject hers,
Airstream Forums - Search Results
I carry a small 12 volt air compressor that I picked up at Harbor Fraight. As little as it gets used I saw no reason to buy a big bucks model.
http://t.harborfreight.com/12v-100-p...sor-61788.html
At the house I use a small 5 Gallon model that serves me well.
You might also consider buying a quality air pressure gauge. The ones on air compressors are rarely correct reading. Also a tire pressure monitor system is nice to have for the increased peace of mind they can give.
MICHAEL
Old 05-16-2015, 08:24 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I carry a small (hot dog tank) 120 volt compressor. Porter Cable. Also a 12 volt unit. It would take a really long time to air up a tire with the 12 volt unit.
Have had to winterize on the road a few times in my travels and the 120 volt unit works great for that and maintaining tire pressure.
Old 05-16-2015, 09:27 AM   #4
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
I use a 12vdc Unit I got at Costco. It uses a lot of amps so connects directly to the TV battery. It wii fill a tire from 58# to 65# in 3 minutes.
Ahab is offline   Reply With Quote
Old 05-16-2015, 09:33 AM   #5
AWCHIEF's Avatar
Images: 33
Yep, I can top up all four tires 3 or 4 lbs in under ten minutes. The new 12 volt compressors are very efficient compared to older pumps. I used to have an old Bosch 12 volt pump that took 20 minutes to put a couple of pounds in.
MICHAEL
Old 05-23-2015, 01:05 PM   #6
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
Years ago we bought a two gallon Coleman portable compressor from some big box store (+/- $70). Added quick connects, and Last year replaced the polyvinyl hose with a Goodyear rubber 25' hose. Pretty fast to top off tires (only rarely needed.) Great when we plugged and re-inflated a trailer tire after picking up a tie-wire in road construction zone. Useful too for occasional blow-off nozzle, and helped blow scale out on deck faucet last Summer.
Small enough to run from our 600-watt inverter, and usually run from 1000 watt Yamaha generator. Honestly don't use air compressor even once a quarter, but when you need it, you really do. Two gallon or less takes up little space. Alternatively (and much more expensively) can use 12vdc fixed compressor and tank (as for air horns or lift bags.)
Chasing 75 Degrees,
Jim N5RTG
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 05-30-2015, 10:10 PM   #7
sparkymark's Avatar
2012 25' FB Eddie Bauer
laguna beach , California
I put air horns on my truck with a 5 gallon tank at 175 psi, with a quick connect I can fill up tires on truck and trailer! Air horns of Texas...
Ford F-350 crew cab 4X4 diesel, 25' Jack Bauer edition AS
sparkymark is offline   Reply With Quote
Old 05-30-2015, 10:39 PM   #8
firstwave's Avatar
2006 30' Classic
Santa Fe , New Mexico
I carry this. PORTER-CABLE CMB15 150 PSI 1.5 Gallon Oil-Free Fully Shrouded Compressor. It's small and lightweight but not 12 volt.
Name:	PORTER-CABLE CMB15 150 PSI 1.5 Gallon Oil-Free Fully Shrouded Compressor.jpg
firstwave is offline   Reply With Quote
Old 05-31-2015, 08:24 AM   #9
Tincampers's Avatar
Sneedville , Tennessee
I'm going to try one of these. Amazon is offering a $20 discount through June 15. Got mine for $84 shipped.
Tincampers is offline   Reply With Quote
Old 05-31-2015, 07:31 PM   #10
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I just bought this one from northern tool - little use so far but seems solid so far
Name:	ImageUploadedByAirstream Forums1433118647.389082.jpg
Got it for 60 bucks - can return if I don't like it within a month and any defect they replace in store within 2 years manager told me
PharmGeek is offline   Reply With Quote
Dweeb air bag compressors? Mike Leary Classic Motorhomes 13 01-01-2013 02:51 PM
Air compressors? cynthia Tires 16 08-06-2005 06:01 PM
Compressors and winterization luckydc Winterizing, Storage, Carports & Covers 7 11-28-2004 11:06 AM
