Adding a 2nd AC on a Ducted Air AS?
Hi Team,
I have seen posts where folks with a pre-2016 AS would add a second AC in place of the BR Fantastic Fan.
To compensate for the AS only being wired for 30 amps, a separate wire was run to a second 30 amp connector near the original. When they needed the second AC they would use a Y-cable from a 50 Amp service to power the two 30 amp plugs.
Folks report having this done at JC and the Camper Clinic II,
Has anyone ever done this on a 2016 or newer unit with ducted air?
Dan
