Old 03-23-2016, 12:49 PM   #1
1971 31' Sovereign
Penticton , British Columbia
Question Access water pump and fresh water tank???
Hello everyone,
I have a question for my 1971 31' Sovereign Land Yacht. I'm currently renovating it and wanted to check my fresh water tank and water pump, how do I service this? It's completely boxed in with the sub floor and underbody protection.
Thanks a lot!!!
Sebastian
S. Bade is offline   Reply With Quote
Old 03-23-2016, 03:29 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Yes, it is boxed in, so the only way you can inspect the tank is by removing it. I would recommend filling it up with water, and looking for leaks. If you don't see water dripping, then you are probably OK. The connections to the tank are usually visible via a hole in the subfloor, usually under a gaucho or some cabinetry. The Water pump usually sits on the floor in the vicinity of this hole as well.
To remove the tank, you have to unbolt/rivet the piece of angle that forms the front of the box/frame underneath. This will expose the edge of a 1" thick piece of plywood that the tank sits on. You then need to pull this piece of plywood forward toward the tongue, which will allow the tank to drop down. It is a bear, as the plywood will have expanded and bonded with the rusty angle iron frame. Not recommended just for the sake of an inspection.
good luck!
Fresh water tank and pump CharlieSK Fresh Water Systems 4 08-12-2015 02:16 PM
1969 overland fresh water tank and pump jl12 Airstream Classifieds 0 05-19-2015 10:52 AM
New water pump-? fresh water tank adonh Water Heaters, Filters & Pumps 24 06-19-2008 08:00 PM
Fresh Water Tank Access Badco8 Waste Systems, Tanks & Totes 2 03-25-2007 05:34 AM
Fresh Water Tank Access Badco8 Waste Systems, Tanks & Totes 2 03-24-2007 11:22 PM
