Old 09-29-2016, 05:01 PM   #1
Silvr_Lining's Avatar
2018 Nest
San Rafael , California
A riveting question
I new to riveting... Seems like riveting, like most other repairs in life, are 99% prep and 1% finish. Getting the rivets drilled and removed is the big chore. That's done.
I am ready to re-rivet, but I am concerned about the electrolysis between dissimilar metals. I need to use a washer because the large head rivets wore through the belly pan. Can I use stainless washers, or should I go buy some sheet aluminum and make my own?
The belly pan is riveted to the steel frame, and I don't see any signs of electrolysis there... Some rust, but no white powder at the rivet area.
Slightly confused. I mean, wouldn't the rivet be the first thing to be attacked being its in direct contact with the steel frame?
Silvr_Lining is offline   Reply With Quote
Old 09-29-2016, 05:10 PM   #2
dznf0g's Avatar
Oswego , Illinois
I use squares cut from heavy Guage aluminum.
-Rich-
Old 09-29-2016, 06:12 PM   #3
1977 31' Sovereign
2005 30' Safari
1977 28' Argosy 28
North Port , Florida
When we redid the belly pan we used 1" flat aluminum along the frame rail to reattach everything. We felt this would help spread out the load instead of relying on just the rivet head.
cliffcharb is offline   Reply With Quote
More riveting pictures -- backsides 1959newbie Ribs, Skins & Rivets 12 06-11-2006 06:22 PM
Riveting questions (not) Tin Tortuga Forum Admin, News and Member Account Info 6 10-11-2005 08:39 AM
Riveting questions silverlassie Ribs, Skins & Rivets 6 04-22-2004 11:38 AM
Riveting photos! 3Ms75Argosy Ribs, Skins & Rivets 17 12-04-2002 07:00 PM
Questions on riveting technique 74Tradewind Ribs, Skins & Rivets 6 05-24-2002 10:45 PM
