Old 07-27-2004, 06:33 PM   #1
Jenturnr's Avatar
2006 34' Classic S/O
Hobe Sound , Florida
Cool A/C Blows GFI in Home
Do I need a separate 30-amp hook-up in order to run the a/c in the Airstream while parked in my yard? I keep the unit plugged in to power from house, but GFI blows when I turn on a/c - after a few minutes. Getting prices from electrical contractor to install separate hook-up, but is it necessary? Unit is about 125' away from house.
Thanks for any assistance - BEFORE I pay the Electrical Contractor.
Jennifer
So Fla - and it is hot
Jenturnr is offline   Reply With Quote
Old 07-27-2004, 06:44 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
jen,
you can look here and decide if you need to hire an electrician.
http://www.pljohnson.com/electrical/...voltdrop.shtml
the calculator sez you will need #4 copper conductor for a run of 125 feet at 30 amps. 3% line loss.
read big bucks!
you do not want to scrimp on the wire because the life of your airconditioner depends on "good" voltage. i would not reccomend running your airconditioner on a sub standard circuit because you can burn the compressor out.
the gfi tripping is not good!
john
you call them ferrets, i call them weasels.
Old 07-27-2004, 06:51 PM   #3
Jenturnr's Avatar
Thanks for the info - I will not run the a/c - just stay in the house! Until we are on the road again.
Thanks again - Jennifer
Old 07-27-2004, 07:39 PM   #4
Mine runs on low just fine...
67caravel is offline   Reply With Quote
Is A/C original? whistler Furnaces, Heaters, Fireplaces & Air Conditioning 2 01-19-2004 04:32 AM
34' Excella 1000 needs cooler A/C cjholloway Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-17-2003 06:50 PM
new member/new motor home malski Airstream Motorhome Forums 12 08-09-2003 05:02 PM
understanding A/C options Lexxy Furnaces, Heaters, Fireplaces & Air Conditioning 24 08-02-2003 05:29 PM
A/C blowing the breaker Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 13 07-08-2003 10:52 AM
