Old 03-11-2005, 12:46 AM   #1
'78 20ft argo's tranny
Does anyone know what type of transmission I am looking at?
It a 1978 20ft Argosy Motorhome. The transmission started slipping
and I will need a rebuilt. Before I shop around I would appreciate
information on the same.
Fabian
Fabofabo
fabofabo is offline   Reply With Quote
Old 03-11-2005, 06:39 AM   #2
LOST , Hawaii
Simple way to tell but if this is a 350 engine I would like to know what you find. If it is a 454 I have little doubt it will be a Turbo 475, the 350 wasn't rated for the torque and application.
GM trans of the days for larger vehicles were the turbo 350 and 400/475 (basically the same trans). The Turbo 350 pan is square with the right rear corner cut off. the Turbo 400 has 2 90 angles on the front but the rear is very irregular in shape, a couple of big curves. It also has an electric kickdown, there will be wires into trans that come from a switch high up on the accelerator linkage inside the motor home.
John
74Argosy24MH is offline   Reply With Quote
What's your tow vehicle's rating? John Community Polls 112 01-12-2009 12:13 PM
Start of restoration '77 Argosy 20ft barbwire All Argosy Trailers 18 08-15-2004 07:42 PM
Tranny 'flush' or Filter change Sav'h Steve Mechanics Corner - Engines, Transmission & More... 18 04-02-2004 09:22 PM
How to drop the tranny? (If I even need to) Impala SS Guy Mechanics Corner - Engines, Transmission & More... 13 10-06-2003 08:03 AM
Argosy 20ft MH Chassis / frame JerryT94 General Motorhome Topics 5 04-14-2003 11:33 AM
