Old 07-08-2009, 10:54 AM   #1
corona , California
71 argosy
O.K. new to forums currently do not have a vintage trailer, but wife and I have always wanted one. We were headed home from my office yesterday and only a few miles from home sitting in a yard was a 71-Argosy 24' for sale. Not sure of value but wanted some input It has a couple coats of paint pretty rough but very straight with exception of a few dents in lower front corners, windows all there and good shape, no water damage that can be seen, interior pretty much stripped but walls/roof straight, does have partion walls and tub sill there, floor seems solid, tires flat.
What do I look for it looks like a clean slate to start with.
Thanks in advance for any input.
Jeff
jeffs46 is offline   Reply With Quote
Old 07-08-2009, 11:25 AM   #2
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
71 was the first year for Argosy but that one sounds like a lot of time and money needed to get it camp ready. That year did not have gray tank so one needs to be added. I just finished a restoration on a 28' 1960 that had most everything with it and it took 3 years to complete. Lucky I have 2 finished trailers to use.
You should look for a trailer you can use as is, then get one to work on, it makes it a lot easier to look at all the work needed, when you can go camping right away.
I would think you would have more in it then it could be worth so a starting price should be very low like $500 - $1000 at most.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 07-08-2009, 11:56 AM   #3
corona , California
Thanks for the input The $ is lower end of that and for now we may want to use it more as yard art and spare room for guest's we really at this time dont need something to camp in cause we have a moho. for that.
I would have explained that in first post but didnt want to get too long winded. That mat be the appealing part is its a clean slate. good points taken.
Jeff
Old 07-08-2009, 12:52 PM   #4
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
inspection list
There is an inspection checklist that may help you out with things to look for when you go and look at an AS to buy. Look at the main Portal page on the right hand side under Airstream Inspectors List and you will see an inspection list that you can download or use.
We have an 1978 Argosy 6.7 metre Minuet-a little different than the Argosy. Ours is slightly narrower and has an aluminum floor. Very light to tow and a great little "guest room" when needed.
Good luck in your quest.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Can You Tow Argosy TT with Argosy MH? Overlander & Sea Tow Vehicles 146 06-22-2017 07:21 AM
How to ship a Argosy?Loaded weight of a 22' Argosy outerbanksdeb Shipping & Export/Import 18 12-17-2011 10:53 PM
1986 Argosy ("Square Argosy") 30' overlander64 All Squarestream Trailers 0 05-19-2009 06:42 PM
