Old 07-31-2017, 05:17 PM   #1
2015 30' Classic
Camden , Maine
50 Amp to 30 Amp adapter to 20 Amp outlet??
We own a 2015 50 Amp AS Classic TT with a 50 Amp electrical service. IF I don't run my air at all, and utilize propane options, can I hook up to a 20 Amp outlet using a 30 AMP adapter plugged into a 20 AMP short cord?.....What are my risks, if any, aside from popping a breaker at the source? Thanks to all who offer so much helpful guidance through this resource!! :-)
Reynolds is offline   Reply With Quote
Old 07-31-2017, 05:56 PM   #2
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
I do.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 07-31-2017, 05:58 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The main risk I see is that you've got two electrical connections (between the adapters) that aren't watertight. Wrap the connections with Saran wrap, elevate so the cords droop down in both directions from the connection, and you'll minimize the chance of rainwater getting into the connection.
It's still up to you to make sure the amps you use don't exceed the amps available, but that's true all the time, not just when you're using adapters.
Cats and ultraleather Airstream upholstery don't mix!
Old 07-31-2017, 07:14 PM   #4
Half a Rivet Short
Carlisle , Pennsylvania
Hi
It's surprisingly easy to have things add up to > 20A. Pay close attention to your loads. The cord you use needs to be rated for 20A. That's going to be a fairly heavy wire gauge compared to a normal extension cord. Twelve gauge copper is ok for short runs. For longer runs you'll need 10 gauge copper. If the cord is aluminum wire, use 10 gauge for short runs.
Old 08-01-2017, 04:08 AM   #5
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
No issues, mine is and has been hooked up this way in storage for years, three of my four Airstreams. As Uncle Bob says if a longer run move to heavier gauge. They have been hooked up this way in rain and snow with no problem as have two other trailers in the storage yard. We all use outdoor extension cords.
SAFE TRAVELS
Bud
Starting to Look (AGAIN) Number 5 Hopefully
USAF Training Instructor (TI) - 68-72
Old 08-01-2017, 07:16 AM   #6
Long Island , New York
We do this with a 15 amp circuit which is enough to keep the batteries charged, and run the fridge on electric. No A/C and no water heated for hot water, just to be clear.
Furrion makes short pigtails which facilitate this process. Here is the 30 amp we use:
https://www.amazon.com/Furrion-FP301...15+amp+adaptor
This pigtail is so short that the male plug hangs above the ground, so water intrusion is not too much of a risk. In driving rain and thunderstorms, we unplug the extension cord and bring it inside the screen porch. They probably make a 50 amp to 20 amp version of the pigtail IMO.
Our extension cord is 50' of #12 AWG with ground, to a 15 amp GFI outlet.
Good luck!
Peter
Old 08-01-2017, 10:22 AM   #7
paiceman's Avatar
Good luck!
Peter
I've used this one at my sister-in-laws house.
https://www.amazon.com/Plug-Adapter-.../dp/B00IPUFQM4
SAFE TRAVELS
Bud
Old 08-01-2017, 12:49 PM   #8
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
I concur.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
WBCCI 9164
https://www.facebook.com/groups/2284022111820203/
cazual6 is offline   Reply With Quote
Old 08-01-2017, 01:29 PM   #9
Originally Posted by cazual6 View Post
I concur.
The short pigtails that Bud and I both posted keep the electrical connection off the ground at the trailer, and presumably the other end of the extension cord is plugged into the outlet at the other end.
Thus the risk of water intrusion, and the need for Saran Wrap etc., are minimized.
Old 08-01-2017, 04:02 PM   #10
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
I carry a couple of coke crates to lay on the ground and keep the connection out of unexpected puddles. I have heard of electrocutions being caused by standing water and poorly insulated connections. I had to hook up one night in a downpour. Waited on the electrical until it quit raining as everything was flooded.
guskmg
Old 08-01-2017, 05:02 PM   #11
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
RV Camper Power Adapter Cords 15amp Male Plug to 50amp Female Adapter RV Extension Cords 12-inch(15M50T) at Amazon for 34.99. I use this to run my refrigerator and lights a few days before departure on a 20A circuit. If you turn on the electric side of the hot water heater you will trip the house breaker.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 08-01-2017, 06:17 PM   #12
r carl's Avatar
Lin , Ne
Originally Posted by SCOTTinNJ View Post
I do.
Me too.
Old 08-01-2017, 07:40 PM   #13
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
You will be fine, you could even run a small air conditioning unit with nothing else, oh always use the shortest heaviest chords you can get
bibbs is offline   Reply With Quote
Old 08-03-2017, 04:01 PM   #14
Box Elder (formerly of Center Moriches, NY) , South Dakota
Bad idea to piggyback multiple adapters. EACH electric connection adds to voltage drop. I bought a 50A female ~ 30A male AND, a separate 50A female ~ 15A male. I've never seen a TRUE 20A male adapter (which would NOT be able to be plugged into a standard 15A outlet).
NY24 is offline   Reply With Quote
Old 08-03-2017, 04:06 PM   #15
The Tin Man
2017 27' International
SoCal , California
I plug my 50 amp AS into a 15 amp outlet all the time. Nothing to worry about. No A/C and don't use the microwave/Convection, but it will run your lights and TV, etc.
2017 Serenity 27FB
Registry Name
"Rivets for the Tin Man"
WBCC #4913
sandollars is offline   Reply With Quote
Old 08-04-2017, 07:16 AM   #16
Half a Rivet Short
Hi
If all you are doing it plugging in at home .... forget the adapters and the monster heavy 50A cable. Wire up a heavy duty / 20A extension cord with the 50A connector on the end of it. Less hassle to lug. No connections to fall out or get wet. If it gets destroyed, less expensive to replace.
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 39 08-08-2018 10:58 AM
Hubbell Twist Lock 15 amp (?) Adapter vs Bargman 30 amp painterfam Electrical - Systems, Generators, Batteries & Solar 12 07-26-2015 09:03 AM
50 amp to 30 amp adapter rbs Airstream Classifieds 0 05-04-2015 06:51 AM
50 amp to 30 amp adapter CMSmith Our Community 28 08-14-2012 09:05 AM
power adapter-30 amp-2 15 amp waynemorgan Batteries, Univolts, Converters & Inverters 4 06-11-2007 08:02 AM
