Old 08-03-2017, 05:06 PM   #15
The Tin Man
2017 27' International
SoCal , California
I plug my 50 amp AS into a 15 amp outlet all the time. Nothing to worry about. No A/C and don't use the microwave/Convection, but it will run your lights and TV, etc.
2017 Serenity 27FB
Registry Name
"Rivets for the Tin Man"
WBCC #4913
sandollars is offline   Reply With Quote
Old 08-04-2017, 08:16 AM   #16
Half a Rivet Short
Carlisle , Pennsylvania
Originally Posted by NY24 View Post
Bad idea to piggyback multiple adapters. EACH electric connection adds to voltage drop. I bought a 50A female ~ 30A male AND, a separate 50A female ~ 15A male. I've never seen a TRUE 20A male adapter (which would NOT be able to be plugged into a standard 15A outlet).
Hi
If all you are doing it plugging in at home .... forget the adapters and the monster heavy 50A cable. Wire up a heavy duty / 20A extension cord with the 50A connector on the end of it. Less hassle to lug. No connections to fall out or get wet. If it gets destroyed, less expensive to replace.
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 39 08-08-2018 11:58 AM
Hubbell Twist Lock 15 amp (?) Adapter vs Bargman 30 amp painterfam Electrical - Systems, Generators, Batteries & Solar 12 07-26-2015 10:03 AM
50 amp to 30 amp adapter rbsev Airstream Classifieds 0 05-04-2015 07:51 AM
50 amp to 30 amp adapter CMSmith Our Community 28 08-14-2012 10:05 AM
power adapter-30 amp-2 15 amp waynemorgan Batteries, Univolts, Converters & Inverters 4 06-11-2007 09:02 AM
